-   -   930 Handle door lock problem will not lock (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/730921-930-handle-door-lock-problem-will-not-lock.html)
WERK I 02-13-2013 04:30 AM
Could you provide some clarification? You say the door locks then immediately unlocks. The door lock button on the window sill; does it go all the way down and then come back up?
Or is the door solenoid attempting to lock and then releases?
If you disconnect the battery and try to lock the doors manually, both sides of the car lock properly?
SEE YA 02-13-2013 02:12 PM
The door lock button goes down then back up.
gmendo 02-14-2013 06:38 AM
Not sure about a 930, but on a 928, if the electrical connector at the end of the lock barrel was installed incorrectly, the central locking system will behave just as you described.
SEE YA 02-14-2013 10:10 AM
I thought there was only one way it can fit?
WERK I 02-14-2013 02:51 PM
I'm feeling the same way. This problem is not of a mechanical nature, but more likely electrical. Was the lock assembly removed before powder coating the handle?
SEE YA 02-14-2013 07:14 PM
The lock assembly was not removed. I just removed the door handle?
Thanks for the input people.
WERK I 02-14-2013 07:37 PM
You might want to remove the lock to see if either of the leads are broken. They are really delicate leads and easily broken.
cole930 02-14-2013 08:08 PM
I fought that damn central locking nightmare many times and it's $100
microswitches. About 9 years ago I s--- canned the whole thing and installed a
$25 ebay keyless entry that has worked flawlessly ever since. I smile
every time I lock and unlock the car.
Cole
SEE YA 02-17-2013 07:58 AM
Will spent over three hours today, still no joy ?
jsveb 02-17-2013 08:59 AM
This is not something I am familiar with, since I Don't have central locking.
You say, after locking it, it jumps back up and unlocks autonomously?
If that is the case, have you tried unhooking the battery, and see how it locks all manual?
SEE YA 02-17-2013 09:23 AM
I will try that next thanks.
SEE YA 02-20-2013 02:39 AM
I think the fault could be with the micro central locking loom?
When I was checking it the small bit the turns the plastic tube in the handle had broken off ?
If I am right it moves, forward to turn the plastic tube that fits on the key barrel.
