I would rather be driving
Turbo 914
In a previous thread Cole asked me to post about my turbo 914.
Well It's not a 930. And. Its not 911 based. But it is a Porsche. It does not have a flat six. It does have a flat four. Twin turbo's make up for changes against the Marque. So... Here is the build. Subaru EJ20R JDM twin turbo. 98-99 Subaru GC8/Impreza 5sp transmission. Custom cable shift running Nissan Versa shift column (amazing shifter placement) Megasquirt EFI with custom tune based on STi Ver8 tables. ~1920# with close to 300HP. Yeah, take that. Everything is garage built to comply with rules of the $2011 GRM Challenge. I went in 2011 and blew the motor so I finished dead last. I will go back this year and will have a whole year to sort the car. The new motor is running well. I plan to kick ass and take names this year. There are several things I would love to do to change the build or add performance but I can not to stay within the budget and the rules. Goes Fast... Scares Weak Minded People... Get's lots of compliments.... Handling? Well I have not explored the limits yet. TBD. A few pictures for those who like a visual. ![]() ![]() ![]() ![]()
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Chain fence eating turbo
Very cool Jamie! I wanna ride.
Ok, I'm looking at the right bank turbo.
I see a small canister with single nipple which I assume to be the wastegate. Next to that is a much larger canister. What is its function? That CAC inlet needs a tall F1 type snorkle. Last edited by copbait73; 02-24-2013 at 01:35 PM.. |
Marty,
The small canister is the integral wastegate. The large one is a vacuum diaphram that would "sequentially" open the exhaust cut-out on the second turbo and add boost. I have deactivated it by welding it in the open position and keeping both turbos to spool together.
Yes, they are both really small. probably close in total overall flow of a single turbo factory setup (TD04).
I know the system operates with pressure to open a butterfly valve in the exhaust. Most of the Subaru guys say to just leave it open permanently - and so I welded it open.
I thought about doing a Subi motor 914 if I ever get the current project done. I am also thinking about an Audi powered 2.7T mid engine 911 too..
Nice car and build!!! |
Jamie, thanks for sharing :-)
In the box of weather I should boost my 914 or not :-) As a turbo guy, that might be the way to go :-)
Trond R. 1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc.. 1972 914-6 GT replica project 1986 944 Turbo |
Jamie:
Just way way cool !!!!!!! Thanks so much for posting. Killer car !!!!! Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. |
Care to share info on how you got the Subi trans to work cheaply in your car ???? I know of the pricey ring gear flip but hoped you had something better.
I have a JDM EJ20 to go into my 58 Karmann Ghia. I'd rather not use the built VW trans and have a 5th gear. Thanks
1958 Karmann Ghia |
Build thread.
914World.com - A Porsche 914 Community / Forum / Club AWD-2WD conversion 914World.com - A Porsche 914 Community / Forum / Club There is no easy way to make the Subaru transmission work in the Ghia. Only a reverse ring and pinion will work. These are pricey.
1958 Karmann Ghia |
