klefroid's Avatar
installing cams question
Hi guy's,
my mechanic just started installing my SC cams.
Can someone give me value for the gauge??? ( picture just for example)
Thanks!!! he is just not shore because of different cams then stock...
Old 02-27-2013, 10:52 AM
klefroid's Avatar
Bump :-)
Old 02-27-2013, 11:20 AM
Preferred pronoun:Maestro
Norm K's Avatar
Maybe others here know what you're asking but I have to admit that I don't.
One would think that your mechanic would be familiar with his own dial indicator (you noted that the photo wasn't of his) and how to use it. In addition, it seems to make sense that he'd know, or that you could supply, the cam lobe numbers - assuming he's using his indicator to confirm those advertised numbers.
When in doubt, use overwhelming force.
Old 02-27-2013, 02:00 PM
Brando
quattrorunner's Avatar
Number I remember is 1.7mm
1.5mm is ok too but shoot for 1.7mm
Turbo powa!
1977 911s. it's cool
Old 02-27-2013, 03:36 PM
Brando
close to even as possable more important than the actual number.
Turbo powa!
Champagne on Beer Budget
HelmetHead's Avatar
The CAM manufacturer should have supplied you with the timing specifications.. 1.7mm sounds about right for SC or 964 cams
Einar
www.einarsgarage.com
Instagram @einars_garage
https://www.facebook.com/pages/Einars-Garage/375533809160797
Old 02-28-2013, 07:59 AM
T77911S's Avatar
i agree with the above very much, although i may get critisized. where they ar timed is still very critical, but just make them match in the end. when i say this, if you get one cam to 1.7 and the other to 1.6, try setting the first one to 1.6 so they match.
the cams should be time more so to the cam than what they are in. porsche used several timing specs for the SC cams. others will be able to give you a better idea of which of those would suit this car better. which it comes down to where you want the power band.
one other thing, use the red numberson the dial. on my last car, someone set hte cams to .020 on the black scale which was really .080. so my cams where advanced 15 degrees.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 02-28-2013, 08:38 AM
totle's Avatar
SC cams should be timed from 1.1-1,7mm. 1,65 is a good end result for lower torque
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 02-28-2013, 09:39 PM
