jayhawk's Avatar
SR Sway Bar with RSR Struts
Anybody here installed RSR coilovers (2.25") springs while using a Smart Racing Sway bar? At first look today it doesn't appear that the struts will fit as the springs interfere with the sway bar "arm", ie the sway bar arm is too far "outboard" to allow the strut to bolt up. The arm cant be moved further inboard as the shaft is splined and the splines don't go in far enough.
Surely i am not the first guy to install RSR coilovers on a car with a SR sway bar!
Any thoughts?
Bob
Bob
Past President KCRPCA
1982 930 Track Car "The Pumpkin"
1986 911 Cab
2002 996tt X50 Lapis Blue Street Machine
Old 03-07-2013, 03:49 PM
gumba's Avatar
I use to run that set up on our race car. A tight fit, but it does clear. I used 27mm & 31mm front bars with 2.25" x 9" x 350lb springs
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 03-07-2013, 04:33 PM
