Advice on MDS ignition components needed
Guys, I want to go to MSD ignition on my 930. Looking at the 6AL, what other components do I need?
What coil?
Do I need a Tach/RPM adapter?
Recommendations/advice would be appreciated.
Thanks,
Old 03-19-2013, 07:12 AM
Puny Bird
Mark Henry's Avatar
Depends what you're doing, (what are you using now, is it twin plug, etc.?) base is a 6al and use a MSD blaster coil.
I have a tach adapter that I won't be using. You need one if using a stock VDO, I'm using a Autometer and you don't need the adapter with those.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 03-19-2013, 07:47 AM
E-85 sippin drunk
turbobrat930's Avatar
Also, take a look at using M&W ingnitions instead of MSD....
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 03-19-2013, 08:27 AM
Tinkering Pays!!
mooney265's Avatar
A good read: MSD Success
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 03-19-2013, 08:56 AM
Thanks guys. Keep the advice coming.
Also, I have single plug not twin plug.
Old 03-19-2013, 09:10 AM
I have a 6425 unit with coil and all hardware and wiring. Never installed as i`m going with distributorless Xdi unit instead.
I can give you a good deal on this if your insterested Let me know.
Old 03-19-2013, 09:45 AM
My 82 had a 6AL for years with no problems as long as you use the correct rotor witout a resistor. The tach worked fine plugged right into the sideof the MSD no tach adapter needed in my case. If you do a search on the suject of the rotor with MSD there is plenty of info.
Old 03-19-2013, 03:28 PM
mark houghton's Avatar
Ditto for me....
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 03-19-2013, 03:29 PM
If you're looking for a locked dizzy I have this leftover from my MSD sale.
FS: Rebuilt 930 Distributor
1986 930 Guards Red
Too much to list...Lot's of HP
Old 03-19-2013, 04:35 PM
You guys are a great help. Thank you!
Old 03-21-2013, 05:26 AM
