CVJR's Avatar
Starts but doesn't run...
Thanks in advance for taking a look at my question. My '87 930 will start, idle very low and not throttle up/ makes no power/ feels like not getting enough fuel' running on 3 cylinders. Weird thing is, if I let it sit for 10-15 minutes it will start right up and run smoothly, make good power, etc. This happens when it sits for more than a day. The other observation: When it starts the 2nd time, it runs at a higher idle like cold start, then a couple minutes later back to normal idle. Temp here in MD has been 80-90 degrees when this occurs. What is going on here, didn't see anything like this in the Sticky on starting problems.
'86 Porsche 928S
'87 Porsche 930 Coupe
Old 07-29-2013, 06:40 PM
T77911S's Avatar
always make sure the basics are taken care of. plugs, cap rotor, good wires and no air leaks.
then i would make sure both pumps are working, check fuel pressures
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 07-31-2013, 06:18 PM
CVJR's Avatar
Thanks T77. Basics are in good order. New plugs, wires, cap rotor, valves, etc last Sept/ 1,000 mile ago. Checked for vacuum leaks. Last thing I did prior to that was install Leaske Adj WUR about 18 months ago. Baffling to me that it starts fine 15 minutes after the starts but won't run at first.
'86 Porsche 928S
Old 08-01-2013, 07:12 PM
T77911S's Avatar
makes me think fuel pressures
RACE CAR:: sold
Old 08-01-2013, 07:21 PM
Turbofrog
smurfbus's Avatar
Wur pressures or CO a bit out out of spec
10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg
Old 08-02-2013, 01:47 AM
