DCR Rides
mdripley's Avatar
CDI Box engine wire harness connector
What is the best way to remove the female spade recepticles on the engine wire harness that plugs into the CDI box 6pin?
I would like to reuse those spade receptacle connectors to replace the green wire from the distributor.
Mike
87 930 turbo coupe 3.3L , 4Spd 930 Trans w/LSD , mostly stock for now
Old 09-14-2013, 10:53 AM
DCR Rides
mdripley's Avatar
I figured out how to remove the female terminals by using a tiny screwdriver and sliding it under the bottom of the terminal and pressing lightly upwards releasing the terminal.
Old 09-14-2013, 01:40 PM
oilonly's Avatar
If you don't mind me asking what type wires did you use to replace the green wire?
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD
Old 09-14-2013, 03:19 PM
DCR Rides
mdripley's Avatar
I purchased a 928 green wire from our host and purchased a harness with the proper connector from PartsKlassic the 928 is far longer than the stock 911 wire which is about 6" long the 928 is about 18 inches long so I now have a new wire running from the cdbox all the way to the distributor bad news is you gotta pull the distributor to install the plug end into the distributor port there is not enough room to pull the plug out which is also held captive by a clip screwed to the distributor. no room to get on that screw as well.
Old 09-14-2013, 06:57 PM
oilonly's Avatar
Nice, thank you mdripley.
Old 09-15-2013, 06:08 AM
T77911S's Avatar
i ran new wires to the coil. i used the old ones to pull the new ones thru the original casing that the wires are in.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-15-2013, 03:44 PM
