Banned
Lifting Car via Trailing Arms?
Do you think it is wise/safe to lift the rear of the car via the trailing arms (the meat of the arms - near the wheel hubs) using a heavy duty floor jack with suitable padding?
I ask, because I would like to be able to raise the rear of the car, fairly high, without the wheels/trailing arms drooping downward (I would then put stacked/screwed toghether boards under the wheels and remove the jack).
Whadaya think?
Old 06-08-2014, 05:10 PM
full quack's Avatar
Send a message via Yahoo to full quack
I'd lift the car first via the proper points, set the car in place with jack stands on the torsion bar tube ends. Then jack up each wheel via the trailing arms. Then block up the trailing arms with your screw jacks.
Much safer and much kinder to the trailing arms. Remember, replacement trailing arms are not getting any cheaper these days.
Mark
Old 06-08-2014, 05:54 PM
Banned
Thanks Mark (aka: Sir Slamus-Maximus) - sound advice right thar!
Old 06-08-2014, 06:10 PM
Chain fence eating turbo
I've jacked mine by the trailing arms many times.
Old 06-08-2014, 06:23 PM
Banned
^^^^ Ha - batting 50% now (unlike Paul who "catches" 100% of the time) !!!!
Old 06-08-2014, 06:38 PM
7.0:1 > 11.3:1 > 7.0:1
Trailing arm all the time for me. Great for tire changes. Lifting it high? use the jack point.
Old 06-08-2014, 08:24 PM
full quack's Avatar
Yeh well, husbands have sex wth their babysitters too...but that doesn't make it a good idea.
Sure you might get away with it for awhile, but when you get caught it's a b#&*ch!
New trailing arms (when you can find them) are a cool $1500.00 each, then there are the new wheel bearings + new pivot bushing + alignment.
Just saying.........
Mark
Old 06-09-2014, 12:38 PM
Banned
Say whaaaattttt - that sounds like good work if you can get it?!?!?!?!
Old 06-09-2014, 01:20 PM
