B&B Intercooler Seals
Does one just re-use the inlet/outlet o-rings on the stock intercooler when replacing with a B&B short neck unit?
- 86 Porsche 930 - Mr.Hyde - 86 BMW 635CSi - Dr.Jeykell - 2006 Infiniti M45 Sport https://medium.com/@crashingdoor |
Yep, I believe the OEM o'rings are the correct size (worked for my BB anyway). Check 'em for condition, of course.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
And the factory shroud has to come out it looks like. Anything I should know about the process to remove it?
Looks like I will fab a replacement since the used cooler I bought didnt come with a B&B shroud.
It doesn't hurt to have a few extras on hand. They are pretty easy to pinch and cut.
The B&B intercooler plate is flat sheet metal, cutout for the IC and the mounting holes. They'll likely sell one to you if you don't want to make on from scratch.
Yes -- original o-rings.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
Dug in and got it done, shroud was a pain to get out with a normal allen wrench. Time to go tool shopping.
Yeah, I had to take my shroud out as well. Never did worry about a tight seal since the B&B fit really close to the grill. Purists would say you need to seal to assure maximum air flow through the IC.....but I'm not a purist and didn't see sustained on-boost runs (i.e., tracking) so never worried about it.
Crotchety Old Bastard
You should use new O-rings on your new inercooler. Old O-rings get stretched out and can pinch during installation. The benefits of shrouding your intercooler are worth the effort. No need to have an intercooler if air goes around it rather than through it.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Correct, Brian. One of the finishing touches I had put on the back burner, fabricating a seal.
The o-rings are only a few hundred miles old since I replaced them so I re-used them.
The B&B does fit flush against the tail so I dont think I am going to run a seal. There is however a 5 or 6 inch gap on the drivers side front corner that would normally be filled by the shroud so the plan is to block that off.
^^^ I believe you attached an unedited file...
Not showing up for you? I hate what Yahoo has done to Flickr.
I just added the B& B cooler to my car as well. You are right it fits right up against the tail, but with out the shroud it does allow air to pass right by the cooler. I called B&B and they sent me one for $100 its a very easy install and directs air exactly into the cooler.
They work for me but I can't argue with that. I hate the new "features" they have added.
Banned
![]() The only nudes in there are of Paul so there is nothing we havent all seen before anyway. Cdill - do you have any pics of what they sent you?
Banned
If you choose the HTML radio button instead of embed it will link to the image and remove the slideshow arrows.
