LinkBack | Thread Tools | Rate Thread |
Smart quod bastardus
what is the work around for replacing the pickup coil in my distributor?
I went to the parts pages looking for the signal generator in my 79 930 dizzy:
Pick Up Coil (Pulse Generator) for Ignition Distributor, 911/911 Turbo (1978-89) Brand: Bosch ---- This part is no longer available! What is the work around that you guys are using to replace this part if its bad? I checked my resistance at the ends of the plug into the green signal wire and its within spec, but I dont know if its breaking down when it gets hot since the turbo really cooks the hell out of the distributor cap and rotor and everything inside there. I dont want to replace the dizzy entirely as an only option if this part goes bad. Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
Screw it, just retrofit an old points type ignition. That and a cheap ass NAPA coil, set the point gap to .016 and rock!
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
I wonder if the one for an SC would work if you find one. They use the same cap and rotor so the distributor housing is the same diameter.
You might get some information from Henry or Steve and others on the engine forum. There's someone mentioned on that forum named Aaron that rebuilds them. When it gets to the day all these distributors are used up and the cars are still around then crankfire ignition like electromotive or EFI with coil on plug or wasted spark ignition will probably be next. |
My guess is, the guy Jim is referring to is Aaron from Burn bros in Ca. Another guy who has got an excellent reputation, as far as I know, is Barry Herschon (spelling)
Jesper Carrera 3.0 1975 930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer www.stauningwhisky.dk |
Ingenieur
There are a number of aftermarket (non-Bosch) ones. For instance:
******** Parts Catalog Are you sure it is bad? Did you measure the resistance between the two pins? It is the same part for a lot of vehicles. 1981-1983 Alfa Romeo GTV-6 1979-1981 BMW 528i 1978-1981 BMW 633CSi & 733i 1981-1982 De Lorean DMC12 1978-1981 Mercedes-Benz 280CE 1977-1981 Mercedes-Benz 280E 1977-1980 Mercedes-Benz 280SE 1984-1985 Mercedes-Benz 380SE 1981-1983 Mercedes-Benz 380SEL 1981-1985 Mercedes-Benz 380SL 1981 Mercedes-Benz 380SLC 1976-1980 Mercedes-Benz 450SE 450SEL 450SL 450SLC 1984-1985 Mercedes-Benz 500SEC 500SEL 1977-1980 Peugeot 604 1978-1984 Porsche 928 1980-1982 Volvo GLE 1975 Volvo 160 series 1976-1979 Volvo 260 series 1983-1986 Volvo 760 |
i suspected the same thing on my car. thats why i put an Oscope on it and found the signal upside down. i almost sent mine off to have the advance checked and the coil.
what are your AFR's at 2500 and 3k in 3rd gear? what are your current symptoms?
86 930 94kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ ![]() 01 suburban 330K:: [_ ![]() RACE CAR:: sold |
I think this is within spec so it seems good, I was just wondering if it could be breaking down when it gets hot from all the turbo heat when its running under load. I would just like to have my eggs in a basket when these parts need replacement. Maybe stock up on one now for the future when it truly is NLA. Thanks, Fred
Ingenieur
That sounds nominal. The coil is probably OK. I guess you could always try and measure it hot. It's rare but not unheard of to fail hot.
Stocking up is a good plan. The Double acting vacuum pot is also getting hard to find. |
I would rather be driving
Since you have an MSD ignition I would replace the whole insert with a Crank Optical. I did this on an SC distributor I made into a twin plug unit. Worked great. The plus side is that you have a 12V output square wave that is much less susceptible to noise unlike the mV scale coming from the coil and spider arm.
Are you sure you don't have a break in the green wire somewhere that separates when hot? Are you getting cut out? A friend had a distributor with too much vertical play. The distrubutor would float and there would not be enough overlap between the spider and pickup coil. This caused a low voltage signal and lots of cut out. It was not easy to find that one.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Green wire is new, I replaced that with the new 928 part and wired it directly to the MSD harness. Even went so far as to isolate the signal wiring away from other voltage sources and spark plug wires as best as possible....thinking some EMF from plug wires or other sensor wires in the engine bay might be causing problems. Question: This Crank optical unit fits inside the OEM distributor housing in place of the coil unit and spider gear? Or is this something driven off the crank pulley? Fred
