Is very busy
TheRedSlantnose's Avatar
Porsche Crest Electric fans
Since it's getting hotter in Texas this season, I'll probably need find away to make the cooling system on my 930 Slant more efficient so the engine temp doesn't rise so high whenever I'm caught in traffic. One idea I had in mind was to use electric fans in the engine bay. I was thinking I could place them inside the rear spoiler over the intercooler, like on the 996 and 997 to blow more air onto the engine. Is this a good place to put electric fans or would I need to put them somewhere else? Or is the cooling system with the one engine fan, flowing air, and oil already efficient enough to make electric fans unnecessary? This is only an idea so far, so I haven't attempted it just yet, and I want to know if it's even a good/practical idea.
Thanks,
Jason
1987 930 Slantnose Cabriolet, 545 hp, Guards Red- Weekend cruiser
1986 944 Turbo (951), 350+hp, Guards Red- Track car
2005 Toyota Tundra SR5 Double Cab 4x4, stock 282 hp, Silver- Daily driver
Old 05-04-2014, 02:31 PM
I believe you could put a fan on the oil cooler. If yours is a factory Slant prior to 89, you should have a fan on the bottom of your right rear fender oil cooler. You can always add on a front cooler under the bumper & if space allows install a fan.
88' 930
03 Tacoma, 04 Duramax, 06 R350 Benz
If you are traveling at the speed of light & turn on your headlights, does anything happen?
Old 05-04-2014, 02:36 PM
Is very busy
I have a front-mounted oil cooler on my car, and I think it has a fan, but here I'm thinking about putting fans in the engine bay.
Jason
Old 05-04-2014, 02:41 PM
fan
Never heard of a fan for the engine bay. It already has one. If the intercooler is shrouded, it may only serve to cooler the air for the intercooler. What it needs in heat, is to cool the oil. I am sure there is others with more knowledge on this will be posting.
88' 930
Old 05-04-2014, 02:48 PM
I've gone native
Tt surgeon's Avatar
The fender well fan is only on 89 slants, and not even all of those.
'07 997.1tt
Blk/blk 600hp, bad to the bone
Old 05-04-2014, 04:44 PM
Is very busy
The oil cooler on mine is front-mounted, and I'm not sure if it's equipped with a fan, even though mine is an '87.
Jason
Old 05-04-2014, 05:03 PM
Take the Cayenne on hot days. I've never ever thought Turbos are good grocery getters or stuck in traffic cars. Like taking a Kentucky Derby horse to plow the field.
63 356 So Called Outlaw
76 930
Old 05-04-2014, 05:28 PM
Banned
Jason, electric fans mounted in the tail opening actually have the opposite effect to what you are looking for as they get in the way of designed engine cooling airflow. The primary engine fan on your car moves 1500 liters per second of air at 6K RPM (according to data published by Porsche and verified by others since) - electric fans small enough to fit in the tail, and run off of the amps supplied by the alternator, can not even come close to that sort of output (even at idle), and thus, obstruct airflow.
I also want to add that sometimes you see very small fans mounted to the tail a/c condenser - this is to help cool the refrigerant in stop and go type settings and does not aid in overall engine cooling (can actually increase oil temps due to what I noted above).
Old 05-04-2014, 05:32 PM
The first item is to insure an oil cooler fan. Do you have one? Make sure it works. If you don't have one get one.
I have an 86 stovepipe car and installed an aftermarket fan and manual switch. A thread search will show you how.
Old 05-04-2014, 05:34 PM
Is very busy
I only drive mine on weekends, and there are some cases where I just can't escape the traffic.
Jason
Old 05-05-2014, 05:27 AM
Banned
So how hot do your oil temps get while in heavy traffic? I ask, because I live in North Texas, too, and even on 100 degree days, and in stop and go traffic, I do not see alarmingly high oil temps.
Also, regarding your first post, I'm curious as to what you consider too hot.
Old 05-05-2014, 08:23 AM
Is very busy
My oil temp gauge hovers around the halfway point when idling and just below it when driving on hot days, and it rises above the halfway point when I get stuck in heavy traffic. I honestly think it's too hot when the gauge is over the halfway point, but it's never overheated before.
Jason
Old 05-05-2014, 08:49 AM
Ken911's Avatar
mine does the same i have front mounted oil cooler and there are no fans on it. I'll be figuring something out about a fan in the future. i was thinking of fabbing a shroud between the cooler and the body then placing fans at both ends of it. I have been stuck in traffic here in miami numerous times and had it get so hot that it killed the oil pressure sender.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 05-05-2014, 09:02 AM
Banned
Well, we have differing opinions on what it too hot, then. The just above the sort-of-middle hash mark is about 220 degrees (perfect) and the last hash mark prior to the red is 250(getting on the warm side, but keep in mind that OEM front, oil cooler fan does not even trigger until 248) . . . so I will see temps reach 250-260 on 100+ days, in stop and go traffic, and with the a/c on max, but am not too concerned as those are not critically high temps (especially when not the everyday, normal temps).
That being said, I do plan to increase oil cooling capabilities at some point (and move the f*ck out of the pressure cooker hell hole, too ).
Old 05-05-2014, 09:16 AM
E-85 sippin drunk
turbobrat930's Avatar
This is what I did to mine... (2) dual pass oil coolers, and related lines. (2) fans, one mounted to each oil cooler that are controlled by my ECU...
I did this as I eliminated the engine mounted oil cooler...
[IMG][/IMG]
[IMG][/IMG]
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 05-05-2014, 12:06 PM
Ken911's Avatar
yeah those will not fit in the fender of a slant nose though
2019 Silverado 6.2L
Old 05-05-2014, 12:42 PM
E-85 sippin drunk
Yea Ken, You are right... I wasnt thinking it was a slant. But maybe he can fit something similar in the rear... Hope all is well on your end. Havent caught up with you in awhile!!
Old 05-05-2014, 01:20 PM
