Broken head stud symptoms.
I have low compression in number 5 cylinder, 3L 930. Suspect it is a burnt valve from lack of maintenance/valve clearances. Have not had the time to make a pressure tester yet. This would give me better clues if I could find the time......
Have started to wonder recently if a broken stud would give low compression... without the leak making significant noise when running or under load? I tend to think I would hear a leak of that sort?
Saving for a complete engine rebuild and my mind wonders when thinking about what I may find inside.
Anybody had real world symptoms of broken head studs they can share? I have searched with not much luck.
Old 08-05-2014, 04:41 AM
I've gone native
Tt surgeon's Avatar
Yes, a broken stud could lose compression.......among other things.
'07 997.1tt
Blk/blk 600hp, bad to the bone
Old 08-05-2014, 04:52 AM
Really?
Old 08-05-2014, 05:26 AM
3 restos WIP = psycho
kenikh's Avatar
Finding head nuts in the valve covers when doing a valve adjustment is the sure fire symptom. Take a magnet and pull on every head nut when you have the valve covers off. If any are loose... Broken head stud.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 08-05-2014, 08:01 AM
jbailey930's Avatar
Send a message via AIM to jbailey930 Send a message via Yahoo to jbailey930
Similar sound under accel as bad exhaust gasket.
John
79 930
Old 08-05-2014, 08:28 AM
hobie911's Avatar
Have the studs ever been changed? If not, way likely. They all brake eventually.
Millage???
Rick Dougal
rkdougal@gmail.com
Old 08-06-2014, 07:02 AM
Registerd 930 user nut
DeFreest's Avatar
My broken head stud sounded like Pop Pop Pop through the exhaust system. not like a back fire just a pop when under boost. Cant miss it. Normaly there is no noise except the regular exhaust note. If you hear a pop under boost you have a broken head stud or two.
Old 08-06-2014, 09:31 AM
