Hard to find parts
I'm trying to find some boring old stuff that isn't showing up on Wayne's catalog or in a google search.
Where are you guys sourcing blue and red braided vacuum line? I can get black all day long but red and blue seem to be impossible to find. I ordered a new dizzy pot so I want to run clean, fancy lines from it to the throttle body. Also, can anyone confirm blue braided vac line (bigger size) for the waste gate to intercooler signal line? Or did someone replace that years ago with the wrong stuff? (the stuff in there is the same as what you find going to the brake booster on a 944) I also need a four fuse block. Did Porsche ever use a four fuse block? I have lots of 3 position and 10 position blocks, but I can't seem to find a 4.
JB - BreitWerks www.breitwerks.com 321-806-8664 Engine Rebuild & Restorations |
Where did you find a vacuum pot for the distributor? Would you mind saying how much it was?
thanks. |
Hey Jim. I was hoping you had a source on the vac lines. As for the dizzy pot, I googled bosch distributor vacuum advance module and found one that they claimed was for the turbo. I will double check the part number and operation when it arrives. I think it was fcpauto or something like that for about $130. When the box shows up I will post back and let you know. Pelican has them listed but they are out of stock and listed as OEM which usually means, yeah, it's in the catalog but don't hold your breath.
Thanks for telling me about this place. It's good to know about another parts place. I'm looking at their website now...
Hope you had a good weekend! |
