Metal Guru
So none of you lowriders have bottomed out and crunched the crossover for your headers?
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
Nope...
Rey....77 930 "the Mistress" |
Very good call on the wheels. Now you just need to ditch the mirrors and tail
![]() Enjoy
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
It has a big Garretson IC. I still get compliments on the tail. Care to guess what it is?
63 356 So Called Outlaw 76 930 |
![]() ![]() ![]() ![]() A few tails I could go for.
Banned
^^^ WOW, those are some wood inducing rears right thar!
Banned
Brando
It's a cool tail. Too much color for my car but was thinking If I ever did another tail it might be that one. But with a twist. I'd use a light coat of Bedliner from arosol can to make what looks like a rubber trim like the turbo and Carrera tails. I need more black and I did that to my all fiberglass tail. Looks real and feels good too. Honest it does. I tested it before doing it. I'm going to use it on my splitter up front too. I wonder how rubber might look on the turbo s spoiler?
Hey it's not silicone. Last edited by quattrorunner; 09-26-2014 at 09:22 PM.. |
Banned
Metal Guru
Rey, thanks for your detailed response
Anyone else had an issue?Seems like the 930 might have a little less suspension travel than the 964T. My car is set to 964 RS height (which looks to be a tad higher than RS height of the torsion bar cars) yet I've nailed mine twice. I'm going to change it over the winter to get more clearance.
..my car has coil overs (500lb spring) in the rear along with 935 spring plates and Rebel Racing bearings. Does not bottom out under load and rides pretty smooth considering how low it is.
Metal Guru
Part of the problem is I use H&R reds that aren't as still as your springs. The pot-holed, broken up roads in Michigan won't allow the use of anything stiffer.
Mine rides great, I have not bottomed out the headers or pan or front cross member {tow hooks are another story...I use them as feelers, if you get my drift.}
I can get the left rear tire to just swish the inside of the fender, just inboard of the lip, if I hit an off camber dip while turning right above 70mph. This has occurred just twice in the 5 years I've been driving the car at it's present stance, with only dirt removed, no damage. My car is at least an inch below euro spec.'s, maybe more, never really measured it, but the car sits very low. Mark |
![]() How the previous owner had the car set up....if you cant fully turn the wheel its too low, its now back to ~euro spec. |
Any pics of it now?
Here is mine.
On ER Coils. (400/600) Raised spindles. Never rub scrape or touch ground ever.
Brando
Wow. This is wicked if it never contacts the ground but how damped is it? How much travel? Is it still comfortabel I guess I'm asking. /\ /\
![]() ![]() 25 and 1/4"s front and back to the bottom of the fender lip.
3 restos WIP = psycho
^^^ i want this
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
