Turbo Hooligan
if you are tracking go lower, just raise the pick up points.
Esthetically I like the flares at the tops of the tires.I would lower your nose down and see how you like it.
D-Zug
Old 09-03-2014, 06:47 AM
I'm going adjustable and here are some choices. Are any here that much better or easier to adjust settings?
Or this
63 356 So Called Outlaw
76 930
Old 09-03-2014, 09:34 AM
speednme1's Avatar
Originally Posted by Tippy View Post
PORfect!
Thank you
Or this
I vote for #3....note: if ordering, speak with Clint first...this will insure he has the part in stock....
Rey....77 930 "the Mistress"
Old 09-03-2014, 10:03 AM
jsveb's Avatar
Option 3 is coil-over only, right?
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 09-03-2014, 11:36 AM
speednme1's Avatar
Yes you are correct...if your doing euro height...I think the factory plates should suffice.
Old 09-03-2014, 05:14 PM
Non User
infraredcalvin's Avatar
He's got a 76, so the spring plates are the "non adjustable" types... I don't have any first hand exp., but I've seen a lot of sway away and weltmeister versions on cars and floating around. I think they're basically the same to adjust, prob made by the same Chinese mfg too...
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
‘71 914-6 GT 3.4L twin plug track car
'75 914 GT clone project
'71 914 track car, fresh 2165 FAT motor (for sale soon)
Old 09-03-2014, 06:08 PM
Talked to Clint and he actually did suggest the sway away. Their high end is coil over. So I'll have 29 torsion bars adjustable ride height on an ancient car. What not to like?
76 930
Old 09-03-2014, 06:26 PM
gumba's Avatar
The only down side to the aftermarket plates is you will lose about 1/2" space in the wheel well, which would affect fitting fatter tires.
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 09-03-2014, 06:51 PM
Looks perfect to me.
82 930 Pearl White 3.3 964 cams, K27 HF, Kokeln, fuel enriched, IA fuel head mod, wur mod, crankfire, 2X plug, Aase worked heads. 1bar, GHL, zork, 23/33 bars, low, loud
Old 09-03-2014, 06:52 PM
Turbofrog
smurfbus's Avatar
10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg
Old 09-03-2014, 10:51 PM
Parts came in yesterday. Could have the beast back on the road next week
76 930
Old 09-18-2014, 07:25 AM
full quack's Avatar
Send a message via Yahoo to full quack
OK, here is my take on stance, but it is just my personal taste, way too low for most out there.
Now for the bottom line...What exactly do you want out of your car? If it is just to get it low, then adjustable rear spring plates and twisting down the front adjusters will work.
However, it will ride like s#@t, it will handle like s#@t, trust me I've been right where you are at. I too started with the simple approach, like I noted above, bad end results.
I then went a little further, with various different parts-n-pieces, still no joy.
What I wanted was a low car, that rode well, handled very well, and was not too harsh to live with. When you drop a 930 very far, you lose too much suspension travel, bump compliance and steering balance, not to mention the fact that your suspension is no longer working in the proper range or with the proper geometry.
There is only 1 way to really do it right......
Here is what I ended up with for an overall great package with virtually no compromises.
Rebel Racing front control arm bushings.
Rebel Racing rear spring plate bushings.
22mm front & rear adj. Tarett anti-sway bars.
Wevo weld on rear anti-sway bar mounts.
Strut tower brace.
23mm front torsion bars.
31mm rear torsion bars.
Front spindles raised 40mm by ERP.
ERP bump steer kit with welded braces.
Von front strut inserts, custom valved for my torsion bars.
Von shocks rear, shortened overall length, custom valved for my torsion bars.
Fikse 18" x 11" rear rims with 295-35 BFG KDW 2's.
Fikse 17" x 8.5" front rims with 1/4" additional negative offset with 255-40 BFG KDW 2's.
Corner balanced & with aggressive street alignment.
Tire life, about 10K on the rears & 18-20k on the fronts.
No it was not cheap, but I could have saved about $750 by not trying the first two trial-n-error approaches, and just simply have done it right the first time.
My .02 worth, take it or leave it.
Mark
Old 09-18-2014, 03:57 PM
Here is the stance it's had since 95. It doesn't eat tires and tracks straight and true. I don't want to go much lower so its an ongoing endeavor.
76 930
Old 09-18-2014, 06:03 PM
Kozmo930's Avatar
Mark
well my .02 worth is with Quack ! went the same route and very happy with the balanced idea... spend money wisely
once I saw his car I had to go the same route, ERP and Rebel will help in all areas
Kozmo
Old 09-18-2014, 06:51 PM
onboost's Avatar
Nice stance Les, but you gotta dump those wheels!
My opinion of course, but the latter factory style wheels do nothing for the earlier body style.
RGruppe #180
Old 09-19-2014, 04:52 AM
ahenthus's Avatar
Check out the picture in the first post.
Old 09-19-2014, 06:44 AM
Does anyone recall pre Internet how many people thought those twists were supposed to be the worthy successor to Fuchs? They were only on the 993tt to start then they put them on everything. Oh well anyone want to make me an offer? And to think I passed on many used sets of Ruf for 1,000. Or any # of Fuchs.
76 930
Old 09-19-2014, 07:16 AM
From our host.
76 930
Old 09-19-2014, 09:56 AM
930T Owner
Hams930T's Avatar
Looks great. The RSR look will be very nice for your car sir.
Chris.
Hams930T
2017 Turbo S
Old 09-21-2014, 03:10 PM
Back from the alignment shop. All new suspension. Went with 30mm torsion bars in back which tightened it up a bit. Ready for some fall road trips.
76 930
Old 09-26-2014, 11:46 AM
