Metal Guru
911nut's Avatar
So none of you lowriders have bottomed out and crunched the crossover for your headers?
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 09-26-2014, 02:14 PM
speednme1's Avatar
Nope...
Rey....77 930 "the Mistress"
Old 09-26-2014, 02:30 PM
Very good call on the wheels. Now you just need to ditch the mirrors and tail
Enjoy
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 09-26-2014, 02:51 PM
It has a big Garretson IC. I still get compliments on the tail. Care to guess what it is?
63 356 So Called Outlaw
76 930
Old 09-26-2014, 05:57 PM
A few tails I could go for.
76 930
Old 09-26-2014, 07:55 PM
Banned
^^^ WOW, those are some wood inducing rears right thar!
Old 09-26-2014, 08:04 PM
Banned
Is it a 993 Turbo replica tail? Regardless, it looks really good on your car.
Old 09-26-2014, 08:08 PM
Brando
quattrorunner's Avatar
It's a cool tail. Too much color for my car but was thinking If I ever did another tail it might be that one. But with a twist. I'd use a light coat of Bedliner from arosol can to make what looks like a rubber trim like the turbo and Carrera tails. I need more black and I did that to my all fiberglass tail. Looks real and feels good too. Honest it does. I tested it before doing it. I'm going to use it on my splitter up front too. I wonder how rubber might look on the turbo s spoiler?
Hey it's not silicone.
Old 09-26-2014, 08:19 PM
Banned
Originally Posted by quattrorunner View Post
and feels good too.
That's too much information, bub!
Robby can fix you up with some if you want to give it a try (will be blue, though)!!!
Old 09-26-2014, 08:29 PM
Metal Guru
911nut's Avatar
Originally Posted by speednme1 View Post
Nope...
Rey, thanks for your detailed response Anyone else had an issue?
Seems like the 930 might have a little less suspension travel than the 964T. My car is set to 964 RS height (which looks to be a tad higher than RS height of the torsion bar cars) yet I've nailed mine twice. I'm going to change it over the winter to get more clearance.
Paul B.
'91 964 3.3 Turbo
Old 09-27-2014, 03:50 AM
speednme1's Avatar
Paul didn't know you wanted details..my car has coil overs (500lb spring) in the rear along with 935 spring plates and Rebel Racing bearings. Does not bottom out under load and rides pretty smooth considering how low it is.
Old 09-27-2014, 04:09 AM
Metal Guru
911nut's Avatar
Just kiddin' ya Rey. Thanks for the info.
Part of the problem is I use H&R reds that aren't as still as your springs. The pot-holed, broken up roads in Michigan won't allow the use of anything stiffer.
Paul B.
'91 964 3.3 Turbo
Old 09-27-2014, 07:28 AM
full quack's Avatar
Send a message via Yahoo to full quack
Mine rides great, I have not bottomed out the headers or pan or front cross member {tow hooks are another story...I use them as feelers, if you get my drift.}
I can get the left rear tire to just swish the inside of the fender, just inboard of the lip, if I hit an off camber dip while turning right above 70mph. This has occurred just twice in the 5 years I've been driving the car at it's present stance, with only dirt removed, no damage.
My car is at least an inch below euro spec.'s, maybe more, never really measured it, but the car sits very low.
Mark
Old 09-27-2014, 05:04 PM
How the previous owner had the car set up....if you cant fully turn the wheel its too low, its now back to ~euro spec.
Old 09-30-2014, 07:54 AM
Any pics of it now?
76 930
Old 09-30-2014, 10:43 AM
Old 09-30-2014, 11:00 AM
Here is mine.
On ER Coils. (400/600)
Raised spindles.
Never rub scrape or touch ground ever.
Old 09-30-2014, 07:06 PM
Brando
Wow. This is wicked if it never contacts the ground but how damped is it? How much travel? Is it still comfortabel I guess I'm asking. /\ /\
Old 09-30-2014, 07:20 PM
25 and 1/4"s front and back to the bottom of the fender lip.
76 930
Old 10-01-2014, 08:30 AM
3 restos WIP = psycho
kenikh's Avatar
Originally Posted by 2tt930 View Post
here is mine.
On er coils. (400/600)
raised spindles.
^^^ i want this
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-01-2014, 08:38 AM
