| Registered |
				Windshield Wiper Problem
			Ok, so I know I am taxing the group with a few of my electrical gremlins, but here is one more (I promise this is the last one - for the moment!!) My windshield wipers some times just start wiping on their own and will not shut off unless I pull the fuse. Then I can replace the fuse and life is normal again. I have a new stalk and the intermittent wiper switch (on dash) is working fine (on and off with varying speeds working). Is there a relay behind the heating system? Anybody have a wiper schematic? Thanks, Henry '76 930 | ||
|  09-08-2014, 10:38 AM |
| Registered |
			If it's the same as my 79SC yes there is a relay conveniently located ( just kidding......it's a SOB to get to it)  behind the fresh air plenum. Takes about an hour to get to it. So this is still happening with the new wiper switch installed?
				__________________ Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey | ||
|  09-08-2014, 12:58 PM |
| Registered Join Date: Jul 2006 Location: S. Florida
			You can usually reach that relay much easier by pulling the two left most instruments out of the dash. You can gently let the instruments hang down from their wires so you can see in there with a flashlight and reach in through the other hole.
|  09-08-2014, 03:25 PM |
| River Rat Join Date: Dec 2005 Location: 1000 Islands NY
				 | Quote:
 Subscribed.
				__________________ 1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs. | ||
|  09-08-2014, 03:36 PM |
| Smart quod bastardus | Quote:
 Is something plugged into your cig lighter that might be causing this? Fred
				__________________ 1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" | ||
|  09-11-2014, 08:03 AM |
| Registered |
			yes the problem is intermittent. sometimes I will start the car and the wipers will start wiping. weird. The stick is off, the intermittent switch on the dash is off. Ok, get out, pull the fuse, shut them off. Shut the car off, replace the fuse and they are sitting still. Nothing is plugged into the lighter outlet. New stick. guess I need to investigate the fuse assembly more. or the relay, but that is just for the intermittent function. Ugh, 38 year old beasts!!  At NHMS on Tuesday!!! Henry '76 930 | ||
|  09-12-2014, 10:11 AM |
