-   -   My 1977 930 Restore+update project (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/830997-my-1977-930-restore-update-project.html)
katajism 09-26-2014 11:56 AM
Dupont color for jaguar 1992-2000
code: SDL
Name:Rose Bronze Effect,
recept number H9831
katajism 09-28-2014 10:18 AM
Some porting for the heads. I donīt want make them bigger, just smooth.
This almost the strarting point.https://fbcdn-sphotos-g-a.akamaihd.n...9e4ca23f92d233
This have better shape, but itīs not ready. https://fbcdn-sphotos-a-a.akamaihd.n...5051fa5f4bdab9
MikeD930 09-28-2014 03:46 PM
It's good to see a 930 being rescued. I like the unique color of your car.
Good job cleaning up the ports!
katajism 10-02-2014 04:21 AM
For E85 fuel and EFi I choose these Bosch Ev14 injectors. Type is 0280158040 , and flow is 980 cm3 / min( 3bar)
http://www.auimg.com/img/produkte/bm...80158040_t.jpg
http://www.bosch-motorsport.de/media/catalog_resources/Injection_Valve_EV_14_Datasheet_51_en_2775993867pd f.pdf
Injector injecting head is in quite same position in this 3.2 manifold as it is with CIS system.
https://scontent-a-fra.xx.fbcdn.net/...1f&oe=54C7A679
Fuel supply end of the injector is far away from orginal position. Anyway i need another fuel rails that canīt corrode so easily. https://scontent-a-fra.xx.fbcdn.net/...ef&oe=54866388
katajism 10-07-2014 05:30 AM
"New" fuel rails are made of Saab Biopower (2 pcs) stainelss steel fuelrails. Some cutting and TIG welding needed. Fuel regulators are integrated to fuelrail.
https://fbcdn-sphotos-e-a.akamaihd.n...2bf08aa36b6199
https://fbcdn-sphotos-a-a.akamaihd.n...1197f8859eaf97
BMW TPS sensor and VW MAP sensor
https://fbcdn-sphotos-h-a.akamaihd.n...ea1e54b9eee517
https://scontent-a-fra.xx.fbcdn.net/...cd&oe=54CA7FEF
930cabman 10-08-2014 04:17 AM
Great project and it looks as though you are really attacking it. I must admit, I am envious of you, how do you find the time for such a project?
Keep up the good work, soon you will be rocking the highways and have done it with your hands/skills.
katajism 10-08-2014 05:13 AM
I let paint Car paint service make whole basework and painting. it was like 80 hours...
i am not updateing this in real time, So it seems to be faster than it is.
Soda blaster is not me. Main engine (long block) assmebly is done by professional. So i make EFi system and others and try to use already trusted solutions. This forum have been useful. Exhaust system is 993 headres+ custom connection + 2 pcs of "smart gates".
Igntion sytem layout (bosch controls(from Volvo) +034 motorsport coils)
https://fbcdn-sphotos-a-a.akamaihd.n...9474abc9d19f58
Clewett wheel and my friend made a machined pulse wheel for the crank speed sensor.
https://scontent-b-fra.xx.fbcdn.net/...82&oe=54C60EBF
katajism 10-10-2014 05:23 AM
oil tank cleaning+painting+new sensor seal. https://fbcdn-sphotos-c-a.akamaihd.n...5c045c172f2792
katajism 10-15-2014 04:52 AM
Engine looks so nice. Chain housings were also machined to match lowered Heads.
993 headbolts were used and Pump drive added to SC cams. New sump cover was need, due the 964 oil pump.https://fbcdn-sphotos-h-a.akamaihd.n...ed018d7b3d234d
https://fbcdn-sphotos-e-a.akamaihd.n...f87d92623c3e89
katajism 10-27-2014 01:08 PM
993 headers used for this. One side flanges needed to rotate. Turbo should be on original place. Turbo is custom made HX35/40. Two pcs, of Turbosmart wastegates to keep optimum turbo spooling. Weldings are made by me, as you can see.
https://scontent-a-fra.xx.fbcdn.net/...98547049_o.jpg
https://scontent-a-fra.xx.fbcdn.net/...84275594_o.jpg
https://fbcdn-sphotos-g-a.akamaihd.n...27961021_o.jpg
katajism 11-02-2014 11:41 AM
test fitting.
https://scontent-b-fra.xx.fbcdn.net/...13&oe=54AA9CBA
quattrorunner 11-02-2014 11:52 AM
Nicely done
IMR-Merlin 11-02-2014 12:04 PM
Nice work...
Subscribed.
katajism 11-24-2014 10:48 AM
Makeing of intercooler. I also put 993 air filter housing. It fits to 3.2 intake manifold.
https://fbcdn-sphotos-b-a.akamaihd.n...96771731_o.jpg
Test fitting of a New oil separation system for breather. https://scontent-b-ams.xx.fbcdn.net/...39798740_o.jpg
pu911 11-24-2014 07:30 PM
Awesome work, what is original paint code. I was thinking the 3.0 turbo's and Carrera used a 9bolt crank and 2.7 crank was a 6 bolt, can these be swapped.
Phil
onboost 11-24-2014 08:04 PM
Phil
3.0 turbo's use the same 6 bolt crank as the 2.7.. it gets it 3.0 displacement with larger cylinders. 3.3 turbo's & 84 and up Carrera use the same 9 bolt crank.
