-   -   My 1977 930 Restore+update project (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/830997-my-1977-930-restore-update-project.html)
katajism 09-23-2014 05:23 AM
Hello!
i have long time followed this forum. It is GREAT and helpful.
Now i can share my project.
I bought very bad shape 1977 930 turbo from Japan 4 years ago.
This was the starting point:
https://scontent-a-fra.xx.fbcdn.net/...23&oe=54BCC4B1
https://scontent-a-fra.xx.fbcdn.net/...1c&oe=54829937
https://fbcdn-sphotos-f-a.akamaihd.n...1faa123afcebe3
https://scontent-b-fra.xx.fbcdn.net/...2a&oe=54CC557D
https://fbcdn-sphotos-b-a.akamaihd.n...2aa3913a2b1a18
https://scontent-b-fra.xx.fbcdn.net/...05&oe=5485B09D
speednme1 09-23-2014 08:01 AM
Nice car...are you doing an original resto or are you keeping the Ruf stuff on? I vote to keep the RUF stuff on and add some original early turbo sport seats...:D
katajism 09-23-2014 11:52 AM
I donīt have original parts, so currently will continue with Ruf parts.
All paint was soda blasted away, and some base paint is here. No accidents in body.
Prepairing to move engine+transmission.https://fbcdn-sphotos-e-a.akamaihd.n..._4598405_o.jpg
https://scontent-b-fra.xx.fbcdn.net/..._6303712_o.jpg
Engine removed
https://fbcdn-sphotos-f-a.akamaihd.n..._6040280_o.jpg
quattrorunner 09-23-2014 01:30 PM
Cool project/car.
I didn't think soda would remove paint?
RarlyL8 09-23-2014 05:30 PM
RUF has a couple meanings for this car. Wow. Glad you have the skills and determination to bring it back as it will sure pay for itself now! A couple years ago I could not imagine doing a full restoration with any hope of getting my money back. Very fortunate you are with your purchase timing.
Robbbyg 09-23-2014 06:50 PM
Your car is almost identical to mine with the bumper upgrades,
with the exception your roof is intact lol
DIY resto is the way to go otherwise will cost a fortune in labour,
Keep taking the pics when your finished its great to look at before and after.
Im doing mine anti clockwise lol,
In about 6 months ill meet back where I started from then shes on the road where she belongs.
Good Luck !! with the restoration I wasted too much time with mine trying to figure out what goes where
In the end it will be the best feeling :cool:
http://forums.pelicanparts.com/uploa...1411523375.jpg
wildturkey 09-23-2014 08:19 PM
Interesting it's a 3L with a brake booster?
Robbbyg 09-23-2014 10:21 PM
Brake booster,? none here might have had one with another po , lots of owners and kays
katajism 09-23-2014 11:38 PM
This have also RUF oil cooler in front of the car. Car was orginally sold in Germany, but shipped to Japan. Who have put RUf parts in this car, i have no idea.
Base paint in engine room
https://scontent-b-fra.xx.fbcdn.net/...42&oe=54CC840A
And this engine room is painted by me. Body painting is made by professional.
https://fbcdn-sphotos-a-a.akamaihd.n...0903e100f5a85d
RarlyL8 09-24-2014 04:55 AM
This is going to be nice. I love to see neglected cars brought back to life.
Are you going to swap out the tail for the early model? Be good to paint all at the same time plus give a clue that it is an early 930.
katajism 09-24-2014 11:38 AM
Color is near original but there is no recept to mix old color. This is nearest and it is from Jaguarīs list. I like it a lot.https://scontent-b-fra.xx.fbcdn.net/...66&oe=54CD5D46
https://scontent-a-fra.xx.fbcdn.net/...8e&oe=54CEDE4C
Les Paul 09-24-2014 12:01 PM
Nice color. I like it:)
katajism 09-25-2014 06:13 AM
Engine was running , but not well and lot of oil came out from exhaust. Low oil pressure on idle. So i split the case.
https://fbcdn-sphotos-g-a.akamaihd.n...a0649337da99c2
Crank have scratches. So i bought another. Luckily 2.7 have same as this 3.0 turbo.
Soda blast for cleaning. it is like new !
https://fbcdn-sphotos-d-a.akamaihd.n...c7db604af99092
onboost 09-25-2014 08:45 AM
77 was first year with brake booster being phased in..
onboost 09-25-2014 08:47 AM
^^ Me too!..
What Jag color is that.. name & code?
katajism 09-25-2014 03:47 PM
Pistons and cylindersare ok. Cams are worn out, and turbo have damage. Valve guides are worn. I found nice set of used rebuild turbo heads. Old heads to box and "new" heads under work.
https://fbcdn-sphotos-b-a.akamaihd.n...736a6d157d4a98
https://fbcdn-sphotos-c-a.akamaihd.n...167c731c9c0ab9
cellison 09-26-2014 10:00 AM
wow what a project. keep the updates coming.
katajism 09-26-2014 11:02 AM
planned Upgrades:
SC cams
964 Oil pump
Hyd.Tensioners.
Compression ratio from 6.5-> 7.xx
Twin plug
EFI
3.2 intake
Fuel system for e85
Turbo
headers
wastegates
Orginal exhaust +heads+injection system goes to box , and waits if some day i want to make this stock again.
"New" heads have been ported by previous owner to fit 3.2 intake manifold.
https://fbcdn-sphotos-e-a.akamaihd.n..._7247424_o.jpg
Twin plugging+1 mm off from the -87 turbo heads.
https://scontent-a-fra.xx.fbcdn.net/...6_687472_o.jpg
OldSpool87 09-26-2014 11:06 AM
Are you planning any changes to clutch/flywheel? Lighten up that rotating mass can make a difference in responsiveness. At least it did for me.
Sounds like a admirable project.
quattrorunner 09-26-2014 11:12 AM
Me too, lightweight flywheel and aluminum PP does make it a spirited rever.
