My 1977 930 Restore+update project
Hello!
i have long time followed this forum. It is GREAT and helpful. Now i can share my project. I bought very bad shape 1977 930 turbo from Japan 4 years ago. This was the starting point: ![]() ![]() ![]() ![]() ![]()
Nice car...are you doing an original resto or are you keeping the Ruf stuff on? I vote to keep the RUF stuff on and add some original early turbo sport seats...
Rey....77 930 "the Mistress" |
I donīt have original parts, so currently will continue with Ruf parts.
All paint was soda blasted away, and some base paint is here. No accidents in body. Prepairing to move engine+transmission. ![]() ![]() Engine removed
Brando
Cool project/car.
I didn't think soda would remove paint?
Turbo powa! 1977 911s. it's cool |
Crotchety Old Bastard
RUF has a couple meanings for this car. Wow. Glad you have the skills and determination to bring it back as it will sure pay for itself now! A couple years ago I could not imagine doing a full restoration with any hope of getting my money back. Very fortunate you are with your purchase timing.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Your car is almost identical to mine with the bumper upgrades,
with the exception your roof is intact lol DIY resto is the way to go otherwise will cost a fortune in labour, Keep taking the pics when your finished its great to look at before and after. Im doing mine anti clockwise lol, In about 6 months ill meet back where I started from then shes on the road where she belongs. Good Luck !! with the restoration I wasted too much time with mine trying to figure out what goes where In the end it will be the best feeling ![]()
Wheels Last row 1977 3.0 930 260hp built, still reassembling Row 1998 996 MK1 3.4 296hp new daily driver |
Interesting it's a 3L with a brake booster?
Brake booster,? none here might have had one with another po , lots of owners and kays
This have also RUF oil cooler in front of the car. Car was orginally sold in Germany, but shipped to Japan. Who have put RUf parts in this car, i have no idea.
Base paint in engine room ![]() And this engine room is painted by me. Body painting is made by professional.
This is going to be nice. I love to see neglected cars brought back to life.
Are you going to swap out the tail for the early model? Be good to paint all at the same time plus give a clue that it is an early 930.
Color is near original but there is no recept to mix old color. This is nearest and it is from Jaguarīs list. I like it a lot.
Nice color. I like it
63 356 So Called Outlaw 76 930 |
Engine was running , but not well and lot of oil came out from exhaust. Low oil pressure on idle. So i split the case.
![]() Crank have scratches. So i bought another. Luckily 2.7 have same as this 3.0 turbo. Soda blast for cleaning. it is like new !
77 was first year with brake booster being phased in..
RGruppe #180 So many cars.. so little time!! |
^^ Me too!.. What Jag color is that.. name & code?
Pistons and cylindersare ok. Cams are worn out, and turbo have damage. Valve guides are worn. I found nice set of used rebuild turbo heads. Old heads to box and "new" heads under work.
wow what a project. keep the updates coming.
Charles 88 911 Cab 74 TR6 88 CRX Si 79 930 #632 (sold her and survived her) |
planned Upgrades:
SC cams 964 Oil pump Hyd.Tensioners. Compression ratio from 6.5-> 7.xx Twin plug EFI 3.2 intake Fuel system for e85 Turbo headers wastegates Orginal exhaust +heads+injection system goes to box , and waits if some day i want to make this stock again. "New" heads have been ported by previous owner to fit 3.2 intake manifold. ![]() Twin plugging+1 mm off from the -87 turbo heads.
Are you planning any changes to clutch/flywheel? Lighten up that rotating mass can make a difference in responsiveness. At least it did for me.
Sounds like a admirable project. |
Brando
Me too, lightweight flywheel and aluminum PP does make it a spirited rever.
