930 turbo, scavenge pump back up..
Anything over 2000 RPM's my 930 would blow blue smoke down the road. I found my breather to the scavenge pump was overflowing with oil. So far I have replaced the scavenge pump and all the lines from the pump and on. To me its seems like the turbo is getting to much oil. Pressure is 25psi at 750 RPM's and 60 @ 3000 RPM's
Has anyone seen this?
Found a video on Youtube and my car flows 2-3 times that amount.
https://www.youtube.com/watch?v=4-QnnNnsY6s
thanks.
Old 10-28-2014, 12:05 PM
Bland
unclebilly's Avatar
Yup, I tore out hair with this last year... It turned out to be a loose connection between the scavenge tank and the scavenge pump. This was allowing the scavenge pump to suck air rather than oil. When I would get on boost, the pressure would push oil put of the vent hose and make a big mess.
Old 10-28-2014, 03:12 PM
