GJF GJF is offline
Slantnose from HELL
GJF's Avatar
Originally Posted by Rawknees'Turbo View Post
Getcha suuummmmm, Big Double G!!!
That will be my next project this fall!!!
It changes from time to time.....
Old 07-31-2016, 07:00 PM
Chain fence eating turbo
Originally Posted by GJF View Post
I'm not a fan of Kevlar disc. Kevlar is simply plastic, I'll take a organic/metallic or even worse, a sintered bronze over Kevlar any day.
But it's bulletproof!! LOL, JK.
I've read nothing but good things since it's smoother engaging than organic, is slightly grippier than organic, and does not wear a flywheel out like organic or matallic.
What don't you like??
Old 07-31-2016, 08:51 PM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
Kevlar is plastic, and it is great material for smooth engagment. But if you overpower them they tend to heat up and smear on the flywheel surface. There is metallic in the Kevlar matrix which is the same as organic lining. The smear wears off during normal use, but if your combination is in the upper HP limit of the Kevlar disc it will suffer as far as clamping is concerned. At that point if your making good HP, but don't want the instant off/on performance of a puck (sintered bronze) disc, you have to opt for a heavy metallic organic lining. Yes, it wears out the flywheel. But then again you want HP...... Smooth Toyota like clutch and BIG HP does not go in the same sentence.
Old 07-31-2016, 09:55 PM
The original owner had a 6-puck disc. Milled the FW like butter.
Old 08-01-2016, 04:18 AM
It really has been buttery smooth up until a year ago, then I've been getting very light chatter.
I'll probably go it again since it's only $250.
If it craps out again, I'll go metallic I guess.
What got me into Kevlar, was reading VW Bug drag racers claiming they use Kevlar since it bites harder, doesn't overheat easy, and does not wear out a FW.
Old 08-01-2016, 08:14 AM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
Here ya go Tip
Old 08-04-2016, 06:12 AM
HAHA, showing your old turbos before the swap?
Old 08-04-2016, 06:40 AM
