Need 930 3.0 Intake System
I am looking for a early 930 Intakesystem with the Bosche valve on the side.
Please let me know if you have one or know one for sale. I need it for a 75 Turbo Thanks Steven |
I have intake manifold, recirc. valve and aircleaner assy. Not sure about the throttle body and metering assy, WUR. Etc.
I'll check what is available. |
I probably have the WUR and FD if you don't.
Didn't "Robbbyg" remove his and put a 3.3 one on?
at the Air flow meter is on the right side a Bosch Valve, so this is what i need.
Thanks for your response, hope somebody have one in the storage. Greetings |
Sorry.
Here are some pics from the PArt, maybe this helps http://forums.pelicanparts.com/uploa...1416776784.jpg http://forums.pelicanparts.com/uploa...1416776817.jpg |
What is the Bosch part number? I have a bunch of those from 3.3L engines, may have one from a 3.0L in the mix.
I have only the Porsche Nr. 930 110 115 01 or 930 110 805 00
But is from a 3.0 L not 3.3 |
Bosch number for the 3.3L is 0.438.120.085
Don't know what it is for the 3.0L but it can be found on the metal tag. |
What is #2 in this diagram? The thing sticking out below the fuel distributor.
I've never seen that before. http://forums.pelicanparts.com/uploa...1416776817.jpg[/QUOTE] |
That's a 75 only part with the solenoid on it like that, that's what they used before the auxiliary air regulator.
Are you sure? It looks that would hit the air filter housing on any 930. Also, how does it add air? Doesn't look like air goes into it or out of it.
Yes, I have that on my 75, it pushes the fuel metering plate down about 1/8" when the solenoid is powered.
The '76 housing has a provision for the solenoid but it is not mounted. My guess is the manual throttle that is next to the e-brake did the job just fine.
Thanks. I have never seen a 1975 930. If you want to post some engine pics, I'm sure there are a lot of people here that would be interested in seeing the technology on such an early 930.
Got one today so thanks for the help.
Pics from an early engine will be great and helpfull |
Also i am looking for this Part
Porsche No 930 110 150 4R http://forums.pelicanparts.com/uploa...1417339668.jpg And here a Picture from the Air meter i bought http://forums.pelicanparts.com/uploa...1417339904.jpg And the Bosch no. http://forums.pelicanparts.com/uploa...1417340092.jpg http://forums.pelicanparts.com/uploa...1417340122.jpg |
Also looking for
intake manifold Porsche No 930 110 031 02 or 2R http://forums.pelicanparts.com/uploa...1417340352.jpg |
| All times are GMT -8. The time now is 05:59 AM. |
