IMR-Merlin's Avatar
Hydraulic parking brake options
Anyone have any suggestions on running a hydraulic parking brake on my 930?
$300 for new parking brake cables is a bit high. I have seen hydraulic units used before, but can't find the site.
Old 01-28-2015, 12:34 PM
I never had a hydraulic parking brake on a Porsche.
But I did have one ( after market of course) on a Chevrolet truck and it was fine for about 12 hours, maybe more, but it always bled down, which of course means it released.
I think there is a good reason that no automotive manufacturer has a hydraulic parking brake on their products.
My advice would be to buy the cables, the peace of mind is worth it.
Old 01-28-2015, 12:52 PM
Please don't.
Old 01-28-2015, 01:30 PM
IMR-Merlin's Avatar
Originally Posted by Miguel Antonett View Post
Please don't.
You have any parking brake cables laying around? I am all set with paying $320 for cables including shipping.
Old 01-28-2015, 01:42 PM
IMR-Merlin's Avatar
Plus if I build a shifter tower, I will not be able to use the parking brake.
So I was thinking about something like this.
Park-Lok Hydraulic Brake - Speedway Motors, America's Oldest Speed Shop
Old 01-28-2015, 02:06 PM
gumba's Avatar
I have one in my VW bus. It bleeds down and releases after awhile. I also think they are illegal in some states. I've seen them with a solenoid, which sounds like a better idea, but you would need to check the power draw.
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 01-28-2015, 02:36 PM
Careful of the fine print
The Speedway Park-Lok is a hydraulic
lock that uses the line pressure of the
system to hold your brakes locked. THE
PARK-LOKWILL RELEASE
AUTOMATICALLYWHEN THE
PRESSURE IN THE LINE DROPS. Check
your system carefully for leaks or damage
that could cause an unexpected release.
Bill
1987 Marine Blue 911 Carrera Coupe RIP 01/2011
1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint
Old 01-28-2015, 02:41 PM
IMR-Merlin's Avatar
I read the fine print, I would only want this for running a turbo timer and such.
Old 01-28-2015, 03:31 PM
We have an 07 VW Passat that has a factory hydraulic E-brake. Works great.
Wish I had it in my 930 for the Hargett.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 01-28-2015, 03:43 PM
Shows how dated I am.
I was taught to never trust hydraulics, always use jack stands or lock hydraulic lifts etc.
Rules are different now for some of the new stuff.
Old 01-28-2015, 03:57 PM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
Most hydraulic shops make custom cables for all different applications. I have been toying around with the idea of machining a disc rotor on the drive flange opposite the starter side of the transaxle and use a wilwood mechanical caliper. Still tinkering this idea in my head.
It changes from time to time.....
Old 01-28-2015, 04:27 PM
IMR-Merlin's Avatar
Is that a separate system or a line lock?
Old 01-28-2015, 05:10 PM
Could you (would you want to) replicate the system used on the 991? I believe it's electromagnetic. I drove one about a year ago and thought the e-brake actuation was really slick…just a thought.
Old 01-28-2015, 05:19 PM
Banned
Lies! LIES!!!
I cannot STAND cars w/ switch-style ebrakes... renders ebrake shenanigans and debauchery unpossable!!! (ohsomostespecially missed in my Hurtz rentals!!!)
curse those infernal bastardz who implemented such tortuous punishment devices!!!
SCOFF!!!
Old 01-28-2015, 05:37 PM
lin7310948's Avatar
brendon sent you a private message.
69 bronco..... 91 mustang ssp santa clara county sheriff's office ...2017 focus rs tuned on 93 400 chp
Old 01-29-2015, 08:06 AM
Unfortunately no, but willing to help you out to find them instead of going the hyd route... It is really unsafe to me, a brick would be more reliable. M2c
Old 01-29-2015, 01:27 PM
full quack's Avatar
Send a message via Yahoo to full quack
I put a drag race "Line-Lock" starting line brake lock on my 1966 Mustang, installed on the rear brakes instead of the drag race intended front brakes. Works and stays on until the juice in your battery drops to around 6-7 volts, then it slowly releases pressure. Works for about 4 days just sitting in the garage with the "Line-Lock" activated.
I did this because of an installation of 4 wheel disc brakes, long before anybody had KITS out there, that were more sophisticated.
Just a possible option for you.
Mark
Old 01-29-2015, 01:42 PM
I'm not sure. I'll try to look into it this evening.
Old 01-29-2015, 03:04 PM
Wer bremst verliert
JohnJL's Avatar
The OMP handle is a couple of hundred, plus the master cylinder, lines etc. It will cost more than 320 for proper cables and may be illegal.
Hydraulics are alzo more fun and allow you to drop some unsprung weight which is why i put it in the autocross car. I havent plumbed in the lines yet so I dont know if it will bleed down or will hold.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 01-29-2015, 03:10 PM
IMR-Merlin's Avatar
Well a fellow pelican that I have bought stuff from before chimed in per PM and has a set of cables that I can have for shipping costs..... if he can find them...
Now the next question. Cadmium or Zinc plated steel tube that is in the trailing arm, is that part of the parking brake cable? The cable ran through it, but there was no way to get the cable out. There looks to be a plastic insert in there that keeps the "fork" of the parking brake cable from coming out. So I had to cut the (corroded) cables off to have my wheel bearings serviced.
Old 01-29-2015, 04:17 PM
