redturbo911's Avatar
Yes
+1 This sounds good.
Originally Posted by jwasbury View Post
Not sure how keeping the 3.6 pickled preserves value when the '89 would have had a 3.2 originally no? Running complete 3.6 can probably fetch 10k, so if you go the route of sourcing a complete running 930 engine I say sell the 3.6 to finance it. Now you have turbo for almost 0 invested and you have the 10k budget to upgrade the 930 engine. Bigger Win.
Tony
91 964 c2 black/ Work in progress/Finally back on the road
85 EURO 930 Black slightly moded slowly reviving her
77 911tt EFI wide body red/ Slightly modified SOLD
Old 01-09-2015, 07:14 PM
Banned
nothing to add here
besides
cool screen name - howbout some pixzorz, jah?
Old 01-09-2015, 08:35 PM
clutch-monkey's Avatar
Uncle on here turbocharged his old 3.0L SC for something like two grand tops.. would be easy to do something similar for the 3.6, plus maybe lower the comp if absolutely necessary
Old 01-10-2015, 12:37 AM
If your 3.6 is in good shape, you can do it for 10k, if shopping smartly and doing some work yourself. You have forged pistons that can be milled to 8:1 compression, better heads, and more displacement then 3.3. Your manifold and even headers can be reused. Not ideal, but even RUF has done it. You will need EFI, injectors, intercooler, muffler , and some fabrication. That should give you 500hp on pump gas, with more torque down low. Much faster package for the street.
Old 01-10-2015, 01:29 PM
totle's Avatar
3.6 is a good base for a 3.3 8:5:1 CR engine.
Replace the 964 crank with a 3.0 crank, and you will have a great 3.3 engine since the 3.0 has shorter stroke
Then you will have the cost for EFI. Fuel rails can be used, + some other stuff.
New exhaust, turbo and tuning
Could be a nice project
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 01-10-2015, 02:12 PM
M491/Targa V8/ 550 Spyder
I purchased this 1979 targa V8 conversion on casters and in boxes with a single draw through turbo. I do appreciate a true 911, but this was a fun build. My first twins
Old 01-11-2015, 05:17 PM
Banned
^JEEZUS^
that thing must be an ANIMAL
how about some more pics, and preferably - vids?!
not my baaaag, baaaaby... but that's pretty forkin cool...
Old 01-12-2015, 04:28 AM
Cobalt's Avatar
I have seen numerous Turbo and twin turbo builds on 964 and 993 engines. Low boost will produce roughly 425hp possibly a bit more depending on engine with between .03 and .035 bar.
I have seen track builds with this setup last 20-30k miles if well maintained and many race engines I have seen last as long.
$10k is tight it will get you a stage 1 but stage 2 would be preferable and closer to $12k or more. If you plan on tracking it a stage 2 is a must with a large IC and custom plumbing.
I am currently building a track build the engine will be a 993 varioram engine with twin turbos and a massive IC.
I know this engine will take a beating but it should last me 20k track miles probably more with proper care, cooling and stock internals. This car will not be street legal but you could get similar results with a street exhaust.
Mine will look similar to this one.
BTW these drive far better than the Factory Turbo cars. No lag to speak of and all the boost is up high so it basically just adds a lot of upper end power and torque giving it a very linear N/A feel.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS,
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others
Old 01-12-2015, 07:09 AM
TurboKraft's Avatar
The "Killer Eggplant" was turbocharged and converted to programmable EFI for <$10k. Very basic turbo system, not the most elegant, but it still completely dominated the supercharged 3.6L that preceded it.
Make it a totally DIY job, labor & fabrication -- you might refresh the 3.6 and turbocharge it for that much.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 01-12-2015, 09:16 AM
Here is a couple more pics of my V8 conversion, no video yet.
I am also torn between turbo or supercharging my Euro Row 85 TL Cab. Does anyone know if they offer a thicker head gasket to lower compression? I am going to pull the heads to have the valve guides done, and would like to prep it for boost. I am not interested in changing out pistons at this time.
Old 01-12-2015, 09:52 AM
Mr. C
SAY - 642's Avatar
Donovan Aluminum Block is a great idea. Put that engine in a 914 !
" Mr.C "
Six = Sex
Old 01-13-2015, 06:27 AM
