On full boost they scream!! Love it! Same here on running too rich. Have you tried adjusting the fuel mixture screw on the fuel head?
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C Last edited by JacobS911; 08-29-2015 at 08:52 PM.. |
1988 930 Venetian Blue |
Nice !!! You must be pumped.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
Most Excellent!!
Glad to see that Durabilt HFS found such a good home. If it wasn't 10 AM I'd have a beer after watching that
beancounter
Congrats and good to see you're enjoying the car.
Re: AFR, how rich are you on top? If you don't have data logging, have someone ride with you and do a full throttle pull in 3rd. Have the observer note max AFR at higher RPM and then use that info to make adjustments to the WUR. Better still get some time on the dyno. The Leask unit comes with excellent instructions. You have them, yes?
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
Hey Jeff, i can help with your AFR's . I'll PM you my number, maybe we can get you set
Helio
1986 944 turbo -first car 1997 993 Cab 6 speed-sold 1992 964 C2 turbo SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo |
Thanks Helio! Got your PM. I'm headed out on my boat right now, so maybe we can talk tonight.
