-   -   930 clone restore - if you had it to do all over? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/847975-930-clone-restore-if-you-had-do-all-over.html)
krasuskyp 11-26-2015 05:52 AM
good progress, Bob - keep up the good werk!
and
Ronknees knows alllllllllll toooooooooo wellllllllllll about 3wayjerks!!! :eek: SmileWavy
Ronnie's.930 11-27-2015 09:38 PM
Originally Posted by 911tracker85 (Post 8892908)
. . . my tranny is stuck . . . so just keep jerking away, there were three of us trying the last time. (now I cant imagine what Ronnie would say to THAT).
So yer saying that both Paul and Norm were there helping and still no joy?!?!?! I woulda' thunk that their 2X Popeye arms would have pulled the gearbox inside out, much less unstuck the "tranny"!!! :eek:
911tracker85 11-28-2015 05:39 AM
Paul/Ronnie,
you two did not disappoint me. :eek:
Did you release the throwout bearing?
cannot get the tranny back enough for that. so far maybe 1/4 of an inch space between block and bell housing.
opinion of a couple experienced Porsche wrenches is it is stuck in the pilot bearing.
so gotta just keep jecking until it comes ..... loose.
(Ronnie, that was another for you.)
yesterday got the hood off an the gas tank pulled. today, drop the steering rack and pull the new fuel lines through the tunnel and work at pulling the engine bay wiring harness out.
and probably some more jerking and dismantling.
http://forums.pelicanparts.com/uploa...1448721401.jpg
http://forums.pelicanparts.com/uploa...1448721421.jpg
http://forums.pelicanparts.com/uploa...1448721442.jpg
wayner 11-28-2015 05:59 AM
Originally Posted by 911tracker85 (Post 8451233)
IF YOU HAD IT TO DO ALL OVER, WHAT WOULD YOU DO?
hoping for posts or links to other threads with ideas. I keep seeing post of what people would do different if they had the chance...
Not sure if this is the type of ideas that you had in mind but, after a number of projects, this was how I did the last one:
PAGE 27 - Project Lessons learned
Luislang 11-29-2015 02:01 AM
Gearbox removal
Gearbox should move easily- jacking will break something. Did you remove the clutch release arm from the bottom of the bell housing? (Remove circlip, slide arm off splined shaft) Otherwise clutch throwout bearing release fork won't disengage
911tracker85 11-29-2015 06:55 AM
Luislang,
removing the release fork shaft on the bell housing is how I've done this on 944s.
but from my 911 mentor, Steve Weiner at Rennsport systems and a local P car mechanic, tell me it is probably stuck on the pilot bearing.
once I get the tranny to move back a few inches, then should be able to get my fingers in and release the clutch fork.
so per these experts, just keep pulling on the tranny like a slide hammer until it comes loose.
yesterday continued some teardown. got the front suspension and steering rack dropped to get good access to the fuel lines. now ready to pull the new ones through.
also pulled the front bumper and lower valance and the front oil cooler.
I pulled the headlights to see what I have. the wires to them were cut off or disconnected. based on the docs I got with the car, it appears this slant conversion came from Golden (Ill) Custom Coachworks. found a link via Google, but apparently they are no longer in business. link has lots of pics and info, and says these motors came from RX-7, so hoping I can find info on how to get them working.
http://forums.pelicanparts.com/uploa...1448810679.jpg
http://forums.pelicanparts.com/uploa...1448810703.jpg
http://forums.pelicanparts.com/uploa...1448810733.jpg
http://forums.pelicanparts.com/uploa...1448810756.jpg
http://forums.pelicanparts.com/uploa...1448810778.jpg
911tracker85 11-30-2015 05:52 AM
Wayner,
thanks for the link. but what I am mainly interested in are issues specific to a 930.
off to the shop.
going through all the docs I got with this car from its build, here are a few of the engine rebuild by the PO in 1990.
http://forums.pelicanparts.com/uploa...1448895023.jpg
http://forums.pelicanparts.com/uploa...1448895039.jpg
http://forums.pelicanparts.com/uploa...1448895050.jpg
http://forums.pelicanparts.com/uploa...1448895066.jpg
http://forums.pelicanparts.com/uploa...1448895079.jpg
http://forums.pelicanparts.com/uploa...1448895094.jpg
911tracker85 12-01-2015 07:23 AM
yesterday was more tear down.
definitely past the point of no return.
will do the updates/upgrades on the front suspension before I put it back together.
http://forums.pelicanparts.com/uploa...1448986814.jpg
http://forums.pelicanparts.com/uploa...1448986902.jpg
http://forums.pelicanparts.com/uploa...1448986923.jpg
911tracker85 12-05-2015 05:20 AM
got the tranny off. ignorance issue.:(
well after all the huffing and puffing, what I learned is you need to remove the clutch fork spring.
WSM does not tell you this, or at least I could not find it. WSM just said 'once you have the tranny off .... '.
what I suspect is I had asked a P car mechanic about pulling the tranny and asked if I needed to pull the pivot shaft for the clutch fork as I did on the 951.
turns out he thought I had removed the spring, which I had not. so another Pcar guy told me about that and the tranny fell off in my lap. :D
selling the tranny to a friend who found cracks in his bell housing. so between his tranny and mine hoping to cobble together a good one.
as I am replacing with a 930 4sp, will be putting up the Sachs RSR pressure plate for sale, along with any stuff I wont use.
so next up is get the engine up on the stand, and just keep dismantling.
http://forums.pelicanparts.com/uploa...1449324799.jpg
http://forums.pelicanparts.com/uploa...1449324818.jpg
http://forums.pelicanparts.com/uploa...1449324837.jpg
911tracker85 12-12-2015 09:08 AM
before I do further tear down on the motor, will finish verifying fitment of my new fuel lines so Len can finish them up for me.
http://forums.pelicanparts.com/uploa...1449943483.jpg
dap930 12-12-2015 01:58 PM
Bob,
I can probably help you with the RX-7 retractable headlight mechanism wiring. I have the same setup from Golden Coachworks, which I installed back in 1990. I also modified the linkage mechanism to eliminate headlight shake. I have the round headlights but also have a set of rectangular ones for backup.
911tracker85 12-13-2015 05:26 AM
Dennis,
excellent. I had not done much research on them yet. will reach out when I get to them.
911tracker85 12-27-2015 05:35 AM
the destruction continues.
tore down both doors incl removing PW mech. considering doing this using RS America door panels, but still debating.
http://forums.pelicanparts.com/uploa...1451226827.jpg
http://forums.pelicanparts.com/uploa...1451226635.jpg
and pulled the intake off.
next up, pull the exhaust then leak down and inspection. hoping for good enough numbers to not have to do full rebuild. but will do what is needed.
http://forums.pelicanparts.com/uploa...1451226663.jpg
911tracker85 12-29-2015 05:21 AM
well...... could hear air leaks on all cyl, so it will be a full rebuild.
anyone recognise who made these headers? cannot find any markings. not sure if this is a re-weld or original but no cracks I could see.
http://forums.pelicanparts.com/uploa...1451398853.jpg
http://forums.pelicanparts.com/uploa...1451398870.jpg
Bucketlist 12-29-2015 05:37 AM
Look a lot like my powerhaus headers:
http://forums.pelicanparts.com/uploa...1451399713.jpg
911tracker85 12-29-2015 06:11 AM
Steve,
thanks for this info.
krasuskyp 12-29-2015 06:49 AM
agreed look alot like my Powerhaus headers, however mine have their tag welded onto one of the exhangers
I believe GHL look similar?
onboost 12-29-2015 07:17 AM
[QUOTE=911tracker85;8935342]well...... could hear air leaks on all cyl, so it will be a full rebuild.
Sorry guys, those are early McNeil headers.. built by Kenny McNeil. He also did the original design/set-up & fabrication for both B&B and Powerhaus.
They do look similar to GHL who copied the design.. but are different where the collectors merge.
911tracker85 12-30-2015 06:01 AM
plan to get a set of Brian's headers at some point. but facing a full rebuild and the rest of the body work/paint and the suspension/brakes, new headers will have to wait.:(
Johnysecret 12-30-2015 08:55 PM
Hello everyone! I have a 1980 911 convertible purchased it like this with fiberglass body on it with a 930 turbo engine on it does anyone know the center points of measurements for the body on these Porsches?
My plan is to turn it into a coupe and bring it back to a collectible Porsche
