Post headers install question
I recently put some B&Bs on my 86. It's a CIS engine which was making about 320 rwHP before the install. Leask WUR with MSD trigger at 4k and a K&N filter, no diverter valve.
The engine has always started instantly hit or cold and settles down immediately to a nice idle. Still does. But I have noticed now that about 20 minutes into a drive, it stumble and spits some below 2k, but immediately behaves above 2k. Only change is headers. Coincidence or consequence?
Yes I know it's not good to lug the engine, but I also don't like to do a rolling shift into first, and sometimes I get caught out below 2k in second.
Tnx.
Old 03-24-2015, 02:09 PM
tops911's Avatar
I was always told that because headers are more efficent in letting the engine breathe that an adjustment to the fuel mixture may be required, could be your issue
1982 930, K-27, BL adj. WUR, Rarlyl8 Headers and Hooligan muffler, PK CDI, 22 and 30mm torsion bars, poly bronze bushings 30mm raised spindles and custom valved Bilstein shocks (by Elephant Racing), monoballs front and rear (by Rennline), Alton 17" Fuchs, Fred Cook fuse panel
Old 03-24-2015, 02:43 PM
Not enough information about the motor, the way Brian Leaske's gadgets are adjusted, or the muffler that's on the headers so if the ignition is in a good state of tune and nothing else was changed then it's probably running lean where you feel the stumbling.
A good wideband AFR gauge would display that or you can retune Brian Leaskes gadgets and richen up the middle 4mm allen head adjustment on the bottom of the CPR to lower steady cruise control pressure and see if that cures it.
If you have a B&B single out muffler on the headers you're missng around 30 horsepower because it has high backpressure and doesn't flow well unless all the internal baffles, flow directors, and divider panels are cut out. All of them.
Do that and they sound nice and breathe pretty well but are still heavy.
Old 03-24-2015, 03:33 PM
K thanks. Muffler is Borla four outlet, also have a Zork which I run now and again.
Old 03-24-2015, 05:22 PM
1/8 th turn of enrichment and problem fixed. Also, much less popping on deceleration, more of a burble now.
Old 04-05-2015, 01:11 PM
On the fuel head or CPR? I got Brian's headers going on next week so just curious...
tim
Tim
1986 930
Gone:71,2,4 914's, 70T, 71T(RS),77S
Old 04-05-2015, 05:24 PM
