I have a new 993 diff cover I've been meaning to put on, as they're a step between the stock cast cover and the full on billet. The 993 cover is about 2X thicker, but still cast. |
Would the early short bellhousing 930 trans hold up? That would be a cheaper option than the g50.
^^^ Yes.
personally, I notched the tube so I could move the whole engine trans forward. a couple inches with that weight helps with Front/Rear balance a bit.
Now I need to get a bias valve installed for braking, I have a little too much front bias.... It might change under track conditions with trailing brake though. |
It won't change on the track. I don't believe the bias valve will work (tried that too). Ideally you need a dual m/c set up. We tried a bunch of things, mixing the pads, running a smaller rear tire (295 vs 315) with 255's on the front. The c2 turbo rear caliper is slightly larger than the 930 rear, but really expensive.
If you went the 930 short bellhousing route you would also skip the extra work of fitting the hydraulic pedal assembly, lines, slave etc. |
| All times are GMT -8. The time now is 08:46 AM. |
