Scavenge Pump
Attempting to disassembly my scavenge pump and I'm unable to remove the drive pin (not enough room to slide it out) and the cover won't come off without the drive pin out? Not sure if the pin is to be cut shorter and then slide out? allowing the cover to come off.
Any ideas how I can disassemble this thing.
thanks in advance
Rod
"This Year ferrari's Ass is Mine"
Old 01-21-2012, 07:58 PM
sjf911's Avatar
Recenter the pin and the plate will separate from the housing.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 01-21-2012, 08:28 PM
Thank you Steve
Success.
Old 01-21-2012, 08:50 PM
Quick question- my motor is out right now so I figured I'd ask: is there anything serviceable on these? Meaning, are you disassembling it for inspection, and if you don't like the looks of it it's time for replacement, or is there something you can do to them? Thanks
Ken
1986 930 2016 R1200RS
Old 01-21-2012, 09:40 PM
Just curious, and a while your at it type of PM maintenance, updating with AN fittings and return line filtered and into the vent tower.
Old 01-21-2012, 09:59 PM
I originally serviced the scavenge pump because I had seen a lot of
coking in the return lines and fittings. I also had a slow leaking down the
back corner of the engine. Once I got the pump removed I also noticed
the dive pin was worn badly.
I changed the shaft seal and perimeter gasket on the pump and
replaced the worn drive pin.
Replaced all the original oil lines with 6AN braided lines and fittings,
added an in line (cleanable) filter and relocated the pump outlet hose from
the tank to the crankcase breather cover.
Cole
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 01-22-2012, 07:28 AM
gasket and seal?
Having trouble locating the drive pin, perimeter seal, paper gasket and seal, are these available from our host?
thanks again
Rod
Old 02-05-2012, 12:42 PM
I'm in the same boat... plan to open up my scavenge pump to make sure all is clean and in good shape but haven't been able to locate the replacement parts mentioned above... any suggestions?
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 02-13-2012, 10:16 PM
parts
I had to call Pelican. They have the parts, but I also had a hard time locating them. Philiip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 02-14-2012, 02:26 AM
Gents:
Our gracious host has the seals and gaskets the pins are a special
order from the Fatherland. I have special hardened pins you can
simply cut to length. If anyone needs one just PM me your address
and I would be glad to send you one at no cost.
Cole
Old 02-14-2012, 07:05 AM
Gotcha... so I'm not the only one that can't find it on the website... I'll give them a call.
Cole - I'd likely take you up on the hardened pin material... especially if it means I don't need to wait for something that small from Germany. I'll PM you.
Thanks,
Rob Montgomery
Old 02-14-2012, 08:53 AM
Rob:
Glad to help !!!!!
Cole
Old 02-14-2012, 09:29 AM
sjf911's Avatar
I don't find the O-ring in the PP catalog but the number is 99970728940
The shaft seal and paper gasket are in the catalog as 99911324640 and 93010519705 respectively.
Also, the drive pin is not listed in PET that I can find but it might be the same as the Sportomatic pin which is 90030200100
Sapere aude
Old 02-14-2012, 12:40 PM
Great, thanks Steve
Rod
Old 02-14-2012, 05:37 PM
Update
Just an update, these are all the seals and gaskets from our host and a thank you to Cole for the new hardened pin.
Result is a freshened up pump.
Old 05-10-2014, 02:50 PM
Gonna machine the pulley or make a new spacer.
Old 08-26-2014, 07:13 PM
Forced Induction Junkie
WERK I's Avatar
Cole,
PM sent
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 07-12-2015, 10:54 AM
