puddy's Avatar
Starting my exhaust work...
Just dug into my car after my cracked exhaust in this thread last week...
B&B Exhaust problem
Anyways this is a lot of fun! It seems like I have a lot of gaskets that need replacing as well. Was even considering pulling the whole motor while I'm at it to address some leaks tho I'd rather pull the motor over the winter. Here's a couple pics. I called it a night after dropping the muffler. I sprayed all the header studs with WD40 so hopefully they will come off ok next time I'm working on it again. They are quite rusty tho.
Cheers, Chris
1986 951
SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
Old 07-20-2015, 07:18 PM
puddy's Avatar
Looks like alot of rusty water was being blown out those crusty turbo gaskets! I'm sure this didn't help make power.
Also can anyone recommend a good set of new header bolts/studs? Mine are rusted badly.
Cheers, Chris
1986 951
Old 07-21-2015, 05:33 AM
You have a twisted idea of fun. I hate messing with crusty exhaust stuff.
Assuming you are talking about header flange to exhaust port hardware these should do it. Be sure to use the proper anti-seize for stainless to aluminum. Good luck getting the old studs out...
http://www.summitracing.com/parts/arp-400-8005
http://www.summitracing.com/parts/arp-400-8015
1987 GP White 930
1977 Ford Bronco
Old 07-21-2015, 05:54 AM
puddy's Avatar
OK, thanks!
It is fun, I just hope I can get everything put back together OK. The PO seems to have made his own inner bumper and heat shields. The heat was actually melting the backside of the 964 reflector close to the turbo! I'm going to try and tidy up that whole area.
Cheers, Chris
1986 951
Old 07-21-2015, 07:09 AM
Here's some on ebay for much le$$
M8 x 1 25mm x 50mm Stainless Steel Exhaust Manifold Studs Custom Quantity | eBay
Old 07-21-2015, 11:23 AM
Banned
Chris, just to offer some un-asked-for advice on penetrating oil, WD40 is not up to the task of rusty exhaust components - Kroil (Aerokroil is the spray can version of it) if much better stuff.
http://www.amazon.com/Kano-Aerokroil-Penetrating-aerosol-AEROKROIL/dp/B000F09CEA/ref=sr_1_2?s=automotive&ie=UTF8&qid=1437503621&sr=1-2&keywords=kroil
Old 07-21-2015, 11:33 AM
puddy's Avatar
Great thanks guys!!
Cheers, Chris
1986 951
Old 07-21-2015, 12:11 PM
Banned
If u can find an old Skool pump oil can add half acetone snd half Trans fluid. Best break free on the planet. See here
OT - Penetrating Oil
Old 07-21-2015, 12:49 PM
puddy's Avatar
^^ cool thanks for the tip!
BTW if I get my B&B headers welded up where the crack is, is the much value to them if I were to try and sell them? $500, $1000?
Cheers, Chris
1986 951
Old 07-22-2015, 03:17 AM
Use link below great deal
Google Deal
Stuff works great but ATF and Acetone is much better
Scott
1979 930 - Black on Black and in the woods
"My third child that will cost more in the long run" :shock:
Old 07-22-2015, 04:01 PM
puddy's Avatar
Cool thanks ^^^, but I think I have something in the garage that may work tho.
Also ordered some nice rarely L8 headers this morning can't WAIT to get them!
Cheers, Chris
1986 951
Old 07-22-2015, 05:39 PM
puddy's Avatar
Damn I can't seem to get the exhaust nuts off the studs. Can't get at them with enough space to turn a wrench. Is there a special tool required?
Cheers, Chris
1986 951
Old 07-22-2015, 06:23 PM
Snap a pic so we can see which one.
Maybe a crows foot wrench?
1987 GP White 930
1977 Ford Bronco
Old 07-22-2015, 06:32 PM
puddy's Avatar
We actually got the nuts all off tonight using mostly a flexible brake line wrench and a torch to heat the nuts. A pain in the arse but it's mostly completed at this point now.
Is it recommended to replace studs at this time?
Cheers, Chris
1986 951
Old 07-22-2015, 09:55 PM
puddy's Avatar
So I now have my entire exhaust system off and the whole system looks pretty good it seems the cracks just came as a result of the one hanger breaking and the weight of the waste gate on the pipe. There are no other signs of cracking anywhere else that I can see.
Can anyone tell me what I should look for on the turbo to see if its worn out? It feels like there is a very tiny amount of end play on the turbine wheel. I'm not sure if thats normal or what would be considered excessive? I suppose i'd have to physically measure that play to have an accurate figure. I'm not sure I have the tools to do so at the moment.
Cheers, Chris
1986 951
Old 07-24-2015, 05:33 AM
puddy's Avatar
My oxygen sensor has seen better days but my AFR meter works fine so is there much point in replacing it?
Cheers, Chris
1986 951
Old 07-25-2015, 07:57 AM
jsveb's Avatar
I'd consider the O2 sensor a while-you-are-in-there item...
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 07-25-2015, 08:13 AM
Pieces of steel have broken off of it. They went through the exhaust turbine wheel then. There's probably damage to the turbine wheel you don't know about now.
Yeah, I would say replace it and hope that doesn't happen again.
I wonder if Chris at Turbokraft has seen this happen before.
Old 07-25-2015, 08:24 AM
Crotchety Old Bastard
RarlyL8's Avatar
I have a turbo with a large hole where the impeller use to be. It simply exploded when the entire tip of the O2 sensor broke off and went through it. They didn't know what happened until the O2 sensor was removed, so yes get a new one.
Old 07-25-2015, 10:13 AM
Banned
I've got a spare newer Bosch WB02 you're welcome to - send me some biermonays or something and I'll fire it off to you...
Old 07-25-2015, 03:43 PM
