-   -   Another 911sc Turbo Conversion (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/880468-another-911sc-turbo-conversion.html)
jpnovak 12-28-2015 10:40 AM
Nice. Glad its running well now. The problems you faced are minor and easy to work through.
Now go and enjoy the boost.
flat6pilot 12-28-2015 01:36 PM
Originally Posted by RarlyL8 (Post 8933862)
Cool!
I can see some soccer mom dialing 911 to report a car on fire, ha!
Did you program the Megasquirt to keep dumping fuel even when the throttle is shut?
Not on purpose. It actually goes pretty lean according to my AFR gauge (15-18 range). Is that still to rich?
jpnovak 12-28-2015 01:58 PM
Yes. 15 is Too rich for off throttle. 18 may be OK. Generally you will see AFR go off scale lean when off throttle. Also check to make sure the fuel cut is enabled. That is, if you want to stop the flames.
gavinc69 01-03-2016 06:51 AM
Stop the flames, who would want to stop that light show ;) (note to self, tune for 15 on over run and make sure fuel cut is disabled when I get my EFI up and running :) )
flat6pilot 01-10-2016 09:10 PM
Final pics
Final Completed Pics:
http://forums.pelicanparts.com/uploa...1452488777.jpg
http://forums.pelicanparts.com/uploa...1452488796.jpg
http://forums.pelicanparts.com/uploa...1452488815.jpg
http://forums.pelicanparts.com/uploa...1452488841.jpg
http://forums.pelicanparts.com/uploa...1452488865.jpg
http://forums.pelicanparts.com/uploa...1452488885.jpg
http://forums.pelicanparts.com/uploa...1452488921.jpg
http://forums.pelicanparts.com/uploa...1452488959.jpg
http://forums.pelicanparts.com/uploa...1452488981.jpg
http://forums.pelicanparts.com/uploa...1452488939.jpg
krasuskyp 01-11-2016 06:30 AM
dayum, NICE BUILD Kyle - excellent
that came out great
flames, FTW of course! 8-)
well don - ENJOY!
and, Brando... muwhahahahaa, JNR - love it... keep up the good werk out thar heh heh
gavinc69 01-11-2016 10:40 AM
That's some cool photo's :)
Is the air filter OK in that position if your driving in the wet?
flat6pilot 01-11-2016 01:21 PM
Thanks Paul.
Gavin- So far I've been avoiding the wet. I won't purposely go out if it's raining but I'll probably address the filter location at some point.
Ukusto 01-11-2016 06:53 PM
Your car looks great - nice clean work!
Cheers,
Iain
Bergo 01-14-2016 08:09 AM
this is great, love the build. care to share a link to which intercooler you used? I have an OEM 930 intercooler for my build, but like what you did there. is there anything supporting it in the rear? I also plan on swapping my tea tray out for a duck tail.
JFairman 01-14-2016 08:30 AM
Third pic up from the bottom shows an oil line right up against a header primary tube.
Under full boost those header pipes can become red hot after around 5 seconds and that oil line is reinforced rubber hose under the stainless steel braiding.
The stainless braiding is only for abrasion resistance and the rubber hose under it will eventually melt or become brittle and probably crack and leak if it isn't moved away a little.
You can also wrap the hose with a heat resistant sleeve or protective wrap in that area and secure it in place with stainless steel clamps.
Tippy 01-14-2016 09:36 AM
Yeah, I used header wrap to your point.
flat6pilot 01-14-2016 11:01 AM
Thanks for the tip. I'll heed the warning as I have some heat shield left over. I didn't even think of using it there.
flat6pilot 01-14-2016 11:07 AM
I do have a single support in the rear on the back right (pax) side of the IC. Between the hoses and the single front/back support it's pretty solid... and it's not really a big IC. In fact, it may be a little small but then again I'm not running a lot of boost.
You guys have helped me so much over the years, the least I could do is share my spreadsheet if you need help finding something:
Spreadsheet with parts links and prices:
https://www.dropbox.com/s/7lpg3mnsksgzzmq/_SC%20Turbo%20Parts%20List.xlsx?dl=0
universeman 01-31-2016 05:35 PM
Driving video?
flat6pilot 02-03-2016 12:59 PM
Fuel Pressure Question
I'd like to ask this question before I make any changes/adjustments to my current fuel pressure setting.
Q: Based on this build, I'm using 30# injectors that were of course set up for a NA engine originally. My fuel pressure is currently set at 36psi, should I be running higher than that while staying below about 10psi of boost?
The reason I ask is, while it's not confirmed I'm adding quite a bit of fuel at the top of the tuning cells. I noticed I'm going about 13.5 AFR @ around 5500 RPM and MAP 160.
Below 5500 and 155 it keeps up just fine while achieving about 11.2 AFR in the high boost areas.
It occured to me that, is it possible my injectors are not keeping up? Maybe I'm just overthinking this and should just try the higher VE numbers...
The area in question was at the MAP 155 mark and 5000 RPM and greater. (3 cells)
http://forums.pelicanparts.com/uploa...1454533062.jpg
New correction I added but haven't tried. Does this seem unusually high for you MS users?
http://forums.pelicanparts.com/uploa...1454533075.jpg
kenikh 02-03-2016 02:03 PM
What is your duty cycle on those injectors when things lean out?
Tippy 02-03-2016 02:04 PM
If higher numbers don't change AFR's, yes you're out of injector. Scale stops at 255 IIRC.
Check injector calculators online to know what injector you need. Use multiple calculators to get a feel as they vary.
flat6pilot 02-03-2016 02:28 PM
@ 13.2 AFR
DutyCycle: 140.1
MAP 165
RPM 5000
lite75 02-03-2016 05:16 PM
You need to upsize your injectors.
