3.0 to be converted to 3.2 Twin turbo
Hallo!
I wanna make a tread of my engine project. The engine is a 3.0 -77 case 03. Have bought a new set of cylinder and pistons from Mahle Motorsport. This is a 98mm set for 74,4 crank and 23mm wrist pin. Pauter has manufactured rods who works with 70,4 crank and 23mm pin and they are 1,8mm longer to remain 7.5:1 comp. K16 Turboīs from 993/996 as a start and will be changed for 24/26 later. 3.2 intake manifolds and Iīm going to use this EFI system: http://www.maxxtuning.eu/maxxecu/ Will post pictures during the process :) So here is the very beginning, not that clean yet....... :) http://forums.pelicanparts.com/uploa...1443095071.jpg |
Thanx for sharing your turbo project. I thoroughly enjoy the assembly process .
Uber VW :cool: http://forums.pelicanparts.com/image...6946/39505.jpg |
Hey!
Nice picture :) |
any updates?
Itīs always a issue of time......But I have all the parts. I guess during the Christmas time the engine block will be put together |
Cool project! Will be watching....
Testing the brand new 993TT oil pump with the new sump.
http://forums.pelicanparts.com/uploa...1448702502.jpg http://forums.pelicanparts.com/uploa...1448702538.jpg |
At last the engine building has started.
First step is to do a little better breather job http://forums.pelicanparts.com/uploa...1448811503.jpg http://forums.pelicanparts.com/uploa...1448811662.jpg And some parts waiting for the crankshaft returning from the balancing job. http://forums.pelicanparts.com/uploa...1448811723.jpg |
I thought I was good with a die grinder, but your scallops on the webs look machined.
Great job. |
New turbo squirters mounted
http://forums.pelicanparts.com/uploa...1454802348.jpg http://forums.pelicanparts.com/uploa...1454802365.jpg Engine case closed http://forums.pelicanparts.com/uploa...1454802426.jpg http://forums.pelicanparts.com/uploa...1454802444.jpg http://forums.pelicanparts.com/uploa...1454802459.jpg |
Looking good, what heads are you going to use?
Those with the larger intake ports. They are a little bit ported and matched for the 3.2 brackets and intake manifolds. |
You'll like those bigger ports!
Before and after.
Matching the intake ports for the 3.2 inlet system http://forums.pelicanparts.com/uploa...1460741879.jpg P&C ready for assembly http://forums.pelicanparts.com/uploa...1460742451.jpg Checking deck height http://forums.pelicanparts.com/uploa...1460742566.jpg http://forums.pelicanparts.com/uploa...1460742608.jpg |
http://forums.pelicanparts.com/uploa...1460742734.jpg
http://forums.pelicanparts.com/uploa...1460742771.jpg Timing of cams just for checking valve clearense to piston. And then deassembly for mounting of gasket etc. http://forums.pelicanparts.com/uploa...1460742854.jpg |
Very nice !!!! What cams did you install in your engine?
Have you looked at UMW K16/24 hybrid turbos?
Because I have those for a long time. They are almost like new. But later I'm gonna change to hybrid 24/26 turbos. The have the same flange as K16 so I don't need to modify the exhaust system. I will start with those just to start with smaller turbos and the grow later. |
| All times are GMT -8. The time now is 10:55 PM. |
