VW 612 RS's Avatar
3.0 to be converted to 3.2 Twin turbo
Hallo!
I wanna make a tread of my engine project.
The engine is a 3.0 -77 case 03.
Have bought a new set of cylinder and pistons from Mahle Motorsport.
This is a 98mm set for 74,4 crank and 23mm wrist pin.
Pauter has manufactured rods who works with 70,4 crank and 23mm pin and they are 1,8mm longer to remain 7.5:1 comp.
K16 Turbo´s from 993/996 as a start and will be changed for 24/26 later.
3.2 intake manifolds and I´m going to use this EFI system:
http://www.maxxtuning.eu/maxxecu/
Will post pictures during the process
So here is the very beginning, not that clean yet.......
Old 09-24-2015, 05:10 AM
VW 612 RS's Avatar
Old 09-24-2015, 05:18 AM
Mr. C
SAY - 642's Avatar
Thanx for sharing your turbo project. I thoroughly enjoy the assembly process .
Uber VW
" Mr.C "
Six = Sex
Old 09-24-2015, 06:08 AM
VW 612 RS's Avatar
Hey!
Nice picture
Old 09-24-2015, 06:09 AM
any updates?
Old 11-14-2015, 05:37 PM
VW 612 RS's Avatar
Originally Posted by boosted79 View Post
any updates?
Not yet
It´s always a issue of time......But I have all the parts.
I guess during the Christmas time the engine block will be put together
Old 11-25-2015, 02:59 PM
Chain fence eating turbo
Cool project! Will be watching....
Old 11-25-2015, 04:41 PM
VW 612 RS's Avatar
Testing the brand new 993TT oil pump with the new sump.
Old 11-28-2015, 01:22 AM
VW 612 RS's Avatar
At last the engine building has started.
First step is to do a little better breather job
And some parts waiting for the crankshaft returning from the balancing job.
Old 11-29-2015, 07:42 AM
I thought I was good with a die grinder, but your scallops on the webs look machined.
Great job.
Old 11-29-2015, 10:24 AM
VW 612 RS's Avatar
New turbo squirters mounted
Engine case closed
Old 02-06-2016, 03:47 PM
lite75's Avatar
Looking good, what heads are you going to use?
75 930, 76 930, 83 SC EFI turbo
Old 02-06-2016, 05:52 PM
VW 612 RS's Avatar
Just the original -78 3.0 heads.
Those with the larger intake ports.
They are a little bit ported and matched for the 3.2 brackets and intake manifolds.
Old 02-07-2016, 03:10 AM
3 restos WIP = psycho
kenikh's Avatar
You'll like those bigger ports!
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 02-07-2016, 10:57 AM
VW 612 RS's Avatar
Before and after.
Matching the intake ports for the 3.2 inlet system
P&C ready for assembly
Checking deck height
Old 04-15-2016, 10:51 AM
VW 612 RS's Avatar
Timing of cams just for checking valve clearense to piston.
And then deassembly for mounting of gasket etc.
Old 04-15-2016, 10:57 AM
Porsche 935's Avatar
Very nice !!!! What cams did you install in your engine?
Old 04-15-2016, 01:40 PM
VW 612 RS's Avatar
Originally Posted by porsche 935 View Post
very nice !!!! What cams did you install in your engine?
964
Old 04-16-2016, 01:00 AM
WPOZZZ's Avatar
Have you looked at UMW K16/24 hybrid turbos?
Old 04-16-2016, 01:05 AM
VW 612 RS's Avatar
No, I'm gonna use ordinary K16 from 993/996 as a start.
Because I have those for a long time. They are almost like new.
But later I'm gonna change to hybrid 24/26 turbos.
The have the same flange as K16 so I don't need to modify the exhaust system.
I will start with those just to start with smaller turbos and the grow later.
Old 04-16-2016, 12:39 PM
