gavinc69's Avatar
Wastegate boost source question
Hi guys,
I currently take the boost pressure source line for my wastegate from just after the turbo and before the intercooler.
After getting a larger intercooler and reading a bit more about intercoolers it seems at least some IC's will have a little restriction and cause a very small amount of pressure drop so your not actually getting your full boost pressure to the engine.
Therefore wouldn't it be best if I move the boost pressure source for the wastegate to after the IC so I then get a correct and more accurate pressure reading for the wastegate.
I thought that way it would allow a little more boost to compensate for any pressure loss from the IC??
1980 SC Flatnose, Euro 3.0, LW Flywheel, 993 Cams, Port & Polish Heads, RS Cut Valves, Magnacor Leads, Boxster Brakes, WEVO Mounts, TRG Roll Bars, Rollcage, RSR rear fenders, WEVO Shifter, K27 7200 Turbo, OBX Headers, Tial Wastegate, Omex 710 ECU, 3.2 Intake, Full Bay Intercooler.....400HP
Old 09-24-2015, 11:18 AM
T77911S's Avatar
my RUF IC has a port on it for the WG.
if your boost gauge still reads the same thing then there is not a problem.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-24-2015, 05:12 PM
