klefroid's Avatar
Overboost sensor bad?
Please tell me my over-boost sensor is bad?
If so then I'm a fool not checking that sooner!
Old 11-25-2015, 04:06 AM
klefroid's Avatar
I thought it cut off the fuel if that's bad? Pumps keep running when I unplug the wire.
Or does it cut off the ignition in a way? Maybe that's why I saw a weak spark before?
Edit: My car is a Euro 1977 3.3 (model 78)
Old 11-25-2015, 04:09 AM
klefroid's Avatar
Never mind... ground the wire but no results... I will have a look for mechanic who can solve this... If I'll find one at least.
Old 11-25-2015, 06:55 AM
mark houghton's Avatar
That overboost switch should show very little resistance, because it's intent is to provide a good ground to the wire connected to it. Only when it sees excessive boost pressure will the internal contacts open, breaking the ground connection, which feeds back to your air flow sensor relay (the yellow relay in later cars) to shut the pumps off. If your relay is working correctly, you should be able to disconnect the wire to the boost switch and ground it to the engine somewhere....and your pumps should run as normal. Your pumps should not keep running with that wired unplugged and not grounded.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 11-25-2015, 10:51 AM
Learned something new right there. Wow there`s so much info if you want to understand how everything works.
Hope you get fixed up very soon
Gone!
Old 11-25-2015, 01:05 PM
Well.....that's what we're all here for, to share what little we know and to learn about what we don't. The collective wisdom here is HUGE!!!
Old 11-25-2015, 04:32 PM
^^^ Indeed...
Old 11-25-2015, 05:35 PM
Forced Induction Junkie
WERK I's Avatar
klefroid,
What symptoms are you experiencing?
I'm curious why you have the to meter set to setting shown in the pic. That particular setting is used to test a diode in reverse and standard polarity. If you set your meter to "200" ohms range you will get the actual ohms measured across the contacts of the pressure switch/sensor. The reading you will get should be very close to the reading you would get if you touch the two probes together.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 11-26-2015, 10:12 AM
klefroid's Avatar
Originally Posted by WERK I View Post
klefroid,
I thought it was an open or closed contact... looks like the relay is bridged anyhow.
today I made something (tube) to bypass the inter-cooler and my afr was less then 10 and with the ic 13.3 so it looks like there is an air leak around the inter-cooler... New o-rings used after the problem. I have a few spare ones if needed.
Car does not have any power but drives good when driving slow, ones I push the throttle it stutters.
Old 11-26-2015, 01:14 PM
klefroid's Avatar
Here is an update, after replacing the intercooler afr did not change.
I drove the car and it has more power (like double) +- 200hp
When it comes on boost it looses power an when I release the throttle I hear a loud tshhhhhhh, like an open blow of valve. the warmer the car get's the higher idle afr goes after driving. I have been trying to find a leak by using high flammable spray but no luck.
It's not the intercooler because I bypassed it after the run and afr stay high (15)
I'm getting closer but still not there... Still have a few hours to work on the car today...
Old 11-27-2015, 04:05 AM
WERK I's Avatar
Are you using the stock intercooler? It could be a stuck or leaking recirculating valve.
Dave
Old 11-27-2015, 03:34 PM
klefroid's Avatar
Good one!
Inter-cooler checked multiple times.
I did a test today for a leaking recirculating valve and found this:
So I closed my muffler and oil tank vent. and removed my inter-cooler. pressurized the intake manifold and a decent amount of air came out of the turbo up pipe.
So that would mean that air is passing the piston in the recirculating valve?
I hear the piston moving when I push and release the throttle. Few parts arrived today (spark plug wires and green dizzy wire) so go to sleep early and make my hands dirty tomorrow morning. Is it possible that the piston does not close completely but still operational?
Old 11-28-2015, 01:10 PM
klefroid's Avatar
a bit more additional info:
When I start the car cold and let it idle until it's warm my afr is stable (12.2)
Then I did a test drive and the car has power but still not how it should be.
After 10 min. or so the afr starts to go up as far as 15.5 on idle, so I tried to re-adjust the afr to 12.2 to see how she runs then and she was worse then before. And still making a loud shhhhhhhhh noise when coming off the gas... I'll try to upload a short video later.
EDIT: https://youtu.be/2clYanR0iUI
Old 11-28-2015, 01:19 PM
