shbop's Avatar
Fuel pressure gauge adapter fittings
I'm looking to buy the adapter(s) to put a fuel pressure gauge on my 83' 930 (WUR). If anyone has these parts laying around, and would like to sell them, give me a shout. I'd like to get these from someone who changed their mind, sold their car and removed them, or just used it briefly to test. Thank you!
Jon
Old 02-14-2016, 01:25 PM
Work in Progress
Rich76_911s's Avatar
Look up boxstergt. Len can make you one for a pretty reasonable price.
Old 02-14-2016, 03:07 PM
I made one to install a control pressure gauge with a brass "T" fitting from a local auto parts store. It came with 1/8" pipe threads which is very close to 10x1 metric threads. I ran a 10x1mm tap and die over the threads to modify them and it works fine with no leaks.
I also put a little Permatex non hardening sealant (the brown stuff) on the threads to lubricate them a little while screwing them in and help seal them.
Old 02-14-2016, 10:04 PM
shbop's Avatar
Anyone? Bueller?
Jon
Old 02-18-2016, 06:49 AM
BoxsterGT's Avatar
Porsche Crest
Thank you for the referral Rich.
Here is an adapter I make up to add a pressure sensor to the WUR......
I also have a wide selection of custom Metric fittings and Fuel & Oil hoses for most Porsche models or will build to your specs.
Please email me for more information.
Len at Autosportengineering dot com
Old 02-22-2016, 09:20 AM
gumba's Avatar
I used the method as FJairman to mount a fuel pressure gauge. Works fine with no leaks.
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 02-22-2016, 09:32 AM
BoxsterGT's Avatar
Porsche Crest
Here is a 12mm Banjo that will take a shorter version of the adapter shown above......
It has also been modified to accept a 1/8 MPT pipe fitting, so any variety of fuel components can be attached.
Len
Old 02-23-2016, 10:04 AM
Bucketlist's Avatar
Here is an example of the 1/8 NPT fitting which Len built for my fuel pressure sensor.
1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters.
Old 02-24-2016, 06:38 AM
