Beru COP trigger voltage?
Hi Guys,
I'm at the end of connecting my DTA S80 ecu up to my 3.0 SC engine and I have hit a problem. I decided to use Cayenne Beru COP with internal ignitors for my ignition. I have the pinout as following pin1 Ground ECU Pin2 Ground engine (spark) Pin3 12 volts Pin 4 trigger My ECU coil output wire is at 0v in the off position and 12v to fire the coil. This doesn't seem to work for the Beru coil. I've read that it should be a 5v trigger signal. Have any of you fitted aftermarket ECUs and come across this problem before? Any help would be appreciated. __________________
1983 RHD SC 3.0 1994 RHD E31 850 CSi |
