dos531's Avatar
930 clutch switch
Anybody know if the 930 has the provisions to attach a clutch switch from a 3.2 carrera? I'm looking for a clutch signal for the ms3pro
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'12 Gallardo LP-570-4 Performante
Ducati 748R
Old 09-01-2016, 06:58 PM
Scottsdale Arizona USA
I think you are referring to the flywheel crank position sensor. The 3.2L DME engines with Bosch Motronic had 2 pickups on the flyhweel while the 930 is a CIS without. The exception would be the 1989 and later 964 Turbos. Get the 1989 930 Turbo Flywheel and Clutch.
Day @ Euro Parts West, LLC, Scottsdale, AZ USA // Automotive Part Connectors & EPW MODE : Motorsport Design
+1 (844) URO-PART // mode@europartswest.com
Old 09-04-2016, 06:06 PM
7.0:1 > 11.3:1 > 7.0:1
No switch on the 930 pedal assembly. Shouldn't be hard to improvise and make yourself a small bracket with some old brake light switch or such.
Old 09-04-2016, 06:11 PM
