Brando
quattrorunner's Avatar
3.0t 930 engine questions
this is a cross post.
My cousin drove my car and immediately afterward this.
I have some issues with my 930 engine I think along with a case leak I've had for 35,000 miles. Time for a rebuild I think.
This time I'd like to upgrade performance wise.
As far as cylinder size what's the largest reasonable upgrade for the 3.0 turbo case?
Would 3.3 cylinders and pistons fit?
It will go efi this time I'm thinking.
On a side question deserving another post probably, What could a missed shift do to an engine on a mild over rev? My symptoms are a slight rattle type sound around 3krpm under light load. full throttle is not as or at all noticeable. Is that rod bearings?
Turbo powa!
1977 911s. it's cool
Old 10-03-2016, 10:15 AM
gumba's Avatar
missed shift/overrev could cause bent valves. A leak down test would be a good idea.
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 10-03-2016, 10:25 AM
Brando
I don't even know it happened, I guess we need to ask what else could have happened or if it was just maybe coincidence.
Turbo powa!
Old 10-03-2016, 10:32 AM
T77911S's Avatar
check for broken valve spring.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 10-03-2016, 10:44 AM
Brando
Ok.
Turbo powa!
Old 10-03-2016, 10:56 AM
TurboKraft's Avatar
3.3L P&Cs don't fit the 3.0L: the wrist pins are a different diameter, the rods are a different length, and you'd end up with miserable base compression.
The largest we go on that case without machining is 100mm Nickies, which makes it 3.3L displacement. Add some base compression -- especially given your home altitude -- and EFI, and that will be a blast.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 10-03-2016, 01:33 PM
Brando
Thanks Chris
Turbo powa!
Old 10-03-2016, 01:53 PM
Brando
I'm looking for broken valve spring but I can't see well enough to tell if anything is broken. Is there something that might be obvious without having to take the valves out?
Turbo powa!
Old 10-24-2016, 06:16 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Brandon, what you want to do is put each piston on TDC of the compression stroke (aka - no cam pressure on rocker arms) and then look at the springs while trying to turn them as best you can with your fingers, etc. Also, try to lever the spring down with a larger screwdriver, metal bar, or similar and look for one that has too little resistance or moves in a strange manner. Sometimes a cracked or broken section (inner and outer springs) will become obvious when you do those steps.
Old 10-24-2016, 06:54 PM
Also, here are the tools to actually compress and remove the springs, even with the engine still installed (one for intake and one for exhaust) -
1977 Porsche 911 Turbo Carrera Coupe - Cylinder Head & Valvetrain - Page 4
Old 10-24-2016, 07:14 PM
Brando
Thanks bro
Turbo powa!
Old 10-24-2016, 11:13 PM
Sorry to hear about that. Any news?
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 10-27-2016, 12:30 PM
Brando
Valve springs look fine. I haven't done anything since draining the oil.
Thanks. Working on a rebuild plan.
Turbo powa!
Old 10-27-2016, 12:58 PM
Right on. Bigger, better, stronger and faster. Turbo powa
Old 10-27-2016, 04:27 PM
Brando
Exactly
Turbo powa!
Old 10-28-2016, 03:32 PM
T77911S's Avatar
did you do a comp or leak down.
may just be a lose bracket
RACE CAR:: sold
Old 10-31-2016, 03:11 AM
Brando
Bracket?
Turbo powa!
Old 10-31-2016, 07:07 AM
