BB muffler surgery help..
Hi guys
I took out my muffler to do some polishing and read through some posts saying it was a good idea to cut the BB muffler to remove the baffles.
from what I see its 2 perforated tubes side by side that only communicate by the perforations.from the search engine it looks different then other I seen.
1-do I have a BB muffler?
2-is it worth cutting open to remove these 2 perforated tubes?
I know its not the best muffler but dont want to replace at this time.
thanks guys
thanks guys
Old 05-01-2017, 06:15 PM
Crotchety Old Bastard
RarlyL8's Avatar
It would be very loud if those tubes are removed. They may also be structural. Maybe add more holes? I'd take it apart just to verify what's in there as that will tell you the best course of action. Maybe add a U bend to connect the 2 baffle pipes.
Old 05-02-2017, 04:00 AM
Ken911's Avatar
mine is a dual outlet so you could cut the side open pull the pipe out. weld two exits on. the remove the inlet pipe so it's basically a box with one inlet and dual outlets. flames come out of both pipes when at the track. I was pulled over once though just so he could tell me how awsome it sounded lol.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 05-02-2017, 05:15 AM
mark houghton's Avatar
Actually, I liked my B&B as is was. Still have it but not in service. Needs some major deeep cleaning to remove a bit of burnt on remnants of things that weren't meant to burn in the first place. Mine is single outlet - right side - with a matching muffler tip for the WG dump on the left side.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 05-02-2017, 05:45 PM
Some B&B mufflers had a layer of stainless steel wool packing around the inside about an inch thick.
It can be cut open and then cut all the perforated pipes and baffles out of it, leave the packing, and you'll be surprised at the increased power. It might sound nice too.
Old 05-02-2017, 06:12 PM
