A/F readings
Have not been on in a while but most of you know my car.. It is running great but my gas mileage is so-so. I have a GT35 turbo billet wheel. I just touch the gas and I have 5 lbs boost. Great spooling turbo with EFI. My question is at low boost 5lbs and under I drop down to 12.5 to 12.1 A/F ratio. Is that right or can I lean it out alittle to save some gas.
THere is really no heavy load on the car at that boost level. Thanks John
83 sc cab turbo widebody. 3.5 liter supertec motor, B&B headers, EFI electromotive TecGT, TurboKraft GT35R billet turbo, 964 cams, WM inj, Bell full bay intercooler, Short bell housing turbo 4 speed tranny, roll bar, hargett shifter, |
Uncertifiable!!!
12.5 on boost is safe and appropriate. It's the AFR when cruising, which is most of the time in normal driving, that will gobble up your gas mileage. You should be at 14-14.7. And older cars are likely not to give as good mileage. MHO
Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
