Capt Bob
Slotted rear bumper - 930 Turbo heat
I have searched the forum and and found some information regarding turbo heat and bumper discoloration.
I think I have a couple of issues with my 1982 930 and the hot bumper issue. The heat shield has been removed...not sure how long ago but certainly before I took the car to Florida. Secondly, the Florida thing...hot summer down here...lots of heat no matter what. So I'm not sure if there are slotted bumpers available or should I cut the slots myself to help dissipate the heat from the turbo and exhaust rather than cooking the paint off the bumper. I have not confirmed my timing and air/fuel ratio yet but that is next as well. Thoughts... Bob |
1. Put the heat shield back in the bumper
2. Add a turbine housing heat shield if necessary. Forget the "blanket" type cover, only the all-metal type last, i.e. ones that look like dimpled foil
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
Capt Bob
Chris - just went to your website. Can I install that heat shield around the hot side of the turbo without removing the rear bumper?
Bob -- the heat shield we make is only for Garrett turbos. Yes, it can be done with everything still in the car.
If you have an OEM or K27 turbo, you'll need a foil-style one, and those are safety wired in place.
Bob, I don't know of an easy way to put the heat shield on the bumper with the bumper on. Taking off the bumper is one of the easier tasks with these cars, so if it were me, I would remove the bumper, install the bumper mounted heat shield, install the foil style shield over the turbo and then put the bumper back on.
1988 930 Venetian Blue |
Where can you get the foil style shield?
Thanks, Rahl |
Capt Bob
I have a K27 turbo. Yes I think its time to drop the bumper, install the factory heat shield and the foil style shield.
Now as mentioned above - time to find the foil style shield.
![]() I used the thick stick on aluminum and lined the inside of the bumper. I also slotted it. Not good picture..
81 930 euro sunroof delete Garrett custom turbo, Tec 3 EFI, 964cams, GT3 oil pump Andial intercooler, Tial wastegate RarlyL8 headers and muffler Lindseys 9s 11s |
stock heat shield for rear bumper
I have a heat shied from my 87 - 930 if anyone needs one. Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
I added some heat reflective foil to my factory shield. Doubt it was necessary but I had a bunch left over.
IMG_20161117_183808 by Shannon, on Flickr
- 86 Porsche 930 - Mr.Hyde - 86 BMW 635CSi - Dr.Jeykell - 2006 Infiniti M45 Sport https://medium.com/@crashingdoor |
i was trying to come with a design for something like an air scoop under the car that would direct more air up and over the turbo.
just a note, my turbo runs cooler after the rebuild, but I did have a good bit of coking inside. not sure if it related but it sure seems like it. I also sprayed on a heat reflector
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L |
This is the DEI stuff, we'll see if longevity is any better (I'm skeptical).
Certified User
It gets pretty hot here, so I was more interested in letting the heat out rather than containing it. I was also having oil coking problems, so I figured anything that allowed the heat to escape could only be a good thing.
![]() I removed the valence panel and the rubber seal between the top of the bumper and the body and added a few holes to increase airflow around the turbo. Added benefit is rear weight reduction ![]() ![]() Oh, how I miss that car
Bill 1988 Carrera - 3.6 engine with ITBs, COPs, MS3X 2024 Macan S Day job ... www.jesfab.com.au Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S |
Do you still have the car??? How is the venting system (and the bumper) holding up -- in regards to the heat affecting the grill crossbars? Did you also use some sort of heat shield in front of the bumper/grill? Do you have any pics of the modification in-progress? Thanks. |
Certified User
I ran the car like this for two summers without any adverse effects. The bumper used to get pretty hot, but not to the point where the paint on the bumper was affected.
Unfortunately, I sold the car a few years ago just before prices went crazy.
Certified User
Just found the dimensions of the cutouts. I drilled the 12mm holes and then used a jigsaw to cut out between the drilled holes. Leave enough metal to clean up with a file to get nice straight lines. Naturally, the space for slots depends on the size of your license plate.
Bill, I've had images of your setup forever. Thanks for the schematics!
Extra great. Thank you very much for the design info! |
works really well. |
