1987 930 Turbo ???????
a customer brought in a 911 wide body, as a 930 turbo, car is a bit of a dog and does not appear to be a genuine factory turbo. All checks so far have left me still confused, my best guess is that it may be a 911 wide body non-turbo that was later fitted with a turbo motor ??
Chassis # is WP0ZZZ912HTS121588 as stamped on body.
vin # on door is WP0AB0912HS121588
Engine # is 930 101 1045P
Any help in establishing exactly what this car is would be greatly appreciated ..thx.
Old 10-21-2014, 12:24 PM
I'm no expert but it looks like both numbers indicate 1987 model (H in the 10th slot). Also the 7,8 and 12 slots I believe designate model. Mine read 9,3,0. The ones above read 9,1,1. Is there no option code M491 on the sticker affixed to the frunk?
An '87 930 would have a 4 speed box as well…
Hunt around on the various vin decoders which are helpful.
Good luck.
Old 10-21-2014, 03:41 PM
Driver
Noah930's Avatar
A from-the-factory turbo would have a "3" in the 8th spot in the VIN. WPOZZZ93... The "3" denotes the 930. Instead, a "1" (like what you've posted) denotes a 911.
1990 Black 964 C2 Targa
Old 10-21-2014, 06:59 PM
The engine # you have posted is the casting number/part number for the engine block.
I think that's a part number for a 3.2 Carrera engine, which would be correct for an '87 Carrera.
I'm guessing you have a wide body 911.
Old 10-21-2014, 07:49 PM
Crotchety Old Bastard
RarlyL8's Avatar
Look at the transmission, brakes, tach/boost gage, and banana arms as well.
Old 10-21-2014, 08:09 PM
Bland
unclebilly's Avatar
Yup, 911 with a turbocharged 3.2.
Old 10-28-2014, 02:22 PM
Mike80911's Avatar
The page below will decode the vin for you but the chassis number you listed has 18 numbers it should have 17 you might have typed it in wrong.
Scouser's Porsche VIN Decoder
89 930 Cab Black
11 Cayenne
Old 10-29-2014, 07:22 AM
83 911 Production Cab #10
JJ 911SC's Avatar
If you drop the last digit out (8) it come up with:
Model 91S - Manufacture Year 1987
Unknown coding. Please report this error code (1-91S-72)
If you drop the T between HS out as in WP0ZZZ912HS121588:
Model 911 - Manufacture Year 1987
Coupé (Canada USA spec)
3.2-Ltr, Flat 6-Cyl, 5-Spd Std, DME Bosch L-Jetronic
Who Will Live... Will See
Old 10-29-2014, 08:18 AM
IMR-Merlin's Avatar
I can't believe all this help and NOT one picture of the car was seen. =)
Old 10-29-2014, 08:30 AM
JJ 911SC's Avatar
That is it, same result with the Door VIN WP0AB0912HS121588
Originally Posted by JJ 911SC View Post
... If you drop the T between HS out as in WP0ZZZ912HS121588:
Old 10-29-2014, 08:34 AM
Taken
After 9 years of (mistaken) ownership the car we really have is not the high and mighty 930 cab, but a lowly 3.2 naturally aspirated cab with a 3.3 turbo engine. Now what to do? We were hoping to cash in with the long dollars the 930 will bring, but no. She is still up for sale, best offer.
Old 07-31-2017, 04:23 PM
That sucks big doink
Sent from my SM-N910T using Tapatalk
Old 08-03-2017, 11:09 AM
We have one that matches all the above, too bad the vin does not agree. It says we have a narrow bodied targa roof car. Quite different from our "930". Might be parting this beauty.
Ours does have a G50/01 not sure if a conversion? What are the signs?
thanks
Old 08-07-2017, 02:56 PM
7.0:1 > 11.3:1 > 7.0:1
1987 Is the first year that the 911 was produced with the G50 series gearbox, therefore not a conversion.
Old 08-07-2017, 05:40 PM
