puddy's Avatar
AAR hose collapsing
The hose between the AAR that goes to the back of the motor into the intake collapses sometimes, is this normal? Should I replace it with a thicker walled hose?
Cheers, Chris
1986 951
SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
Old 04-24-2018, 04:51 AM
stevie 77 930's Avatar
Shouldn't that hose be steel reinforced ? Part # 930 110 335 00 listed for a 930/66 engine
1983 911SC
1977 930 Turbo (again)
2018 GTS
2023 Audi A4
'74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 04-24-2018, 08:00 AM
puddy's Avatar
Interesting, i assumed it was a factory hose on it but perhaps it is not, it is a rather soft squishy hose, the kind Rawknees would frown at.
Cheers, Chris
1986 951
Old 04-24-2018, 08:05 AM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Maybe grind some of these up and rub the powder on the squishy hose?!?!
Old 04-24-2018, 08:40 AM
TurboKraft's Avatar
The part supersedes to a C2T hose, and that is 2-ply reinforced.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 04-24-2018, 09:34 AM
puddy's Avatar
OK, thanks fellas, I just remembered my AAR is not in stock location the hose comes off the back of the AAR takes a sharp left turn and is about 8" long, (twice the length of Rawknees hose). I may recreate it with a reinforced hose I have, along with a plastic or aluminum 90 degree elbow and short hose section to go into the AAR. Probably my best solution as I doubt a stock hose will work.
Cheers, Chris
1986 951
Old 04-24-2018, 10:03 AM
Alan L's Avatar
I have the same issue with my hose - and I am pretty sure that bit is all stock - about the only bit that is..
I could not find a suitable substitute, so what I did is put a tight sleeve of another hose (about 20mm long) at the point it was collapsing - to try and wedge it open , at least a bit.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 04-24-2018, 06:16 PM
. . .and is about 8" long, (twice the length of Rawknees hose). . . .
Check PM box for refuting pictorial evidence, PullinMyPuddy (only make sure no family or friends are within eyeshot of your computer or phone screen ).
See post #4 for a medication that might help you with that, bub!
Old 04-24-2018, 06:42 PM
