Vintage 2.7 L rebuild cost compared to a modern water cooled and 911 engine
Good morning gentlemen I've been staring at Craigslist this morning prompted this question. With your help I think I have a pretty good idea of what it's gonna cost to rebuild my 2.7 L, but I'm curious as to that cost/effort compare to a more recent water cooled 911 engine rebuild.
Car and driving experience are totally different animals of course, but there are some interesting cars available for pretty cheap that have me pondering...
Thanks!
1967 912 (now w/ 50% fewer random holes in it)
911 w/ 3.2
1974 914 (3.2L swap underway)
1984 928s (S4 engine and suspension), 1987 928S4
Old 06-26-2018, 07:38 AM
Puny Bird
Mark Henry's Avatar
I rebuild 996 engines (M96/97), basic bare bones using rebuild factory shortblock, no headwork other than pressure test and surface or anything else like fly, clutch, AOS etc $15-17K. This is a basically a slap together get'er running deal.
Full rebuild price with LN goodies, which is just a little bit better than stock HP, is easily the cost of a very well optioned performance aircooled with 50+% increase in HP. Even then the aircooled is likely still cheaper.
Also it takes about $5K in tools to rebuild a 996 engine.
The aircooled engine 2.0 thru 3.6 are all about the same rebuild cost. You'd have to sub out the machining, but many have home built their engines.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 06-26-2018, 10:38 AM
Chain fence eating turbo
The aluminum cases require virtually no machine work vs magnesium. I'd think mag cased engines cost much more.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 06-26-2018, 01:24 PM
Thanks for the level set
911 w/ 3.2
Old 06-26-2018, 01:27 PM
Puny Bird
Mark Henry's Avatar
Yes, but for ballpark it's close enough.
The OP is active on 914world so I figured he's talking about an aircooled engine for a 914 six conversion, so I was factoring in the conversion fly/clutch he would need on a 3.0 and up.
Old 06-26-2018, 02:18 PM
Hi Mark!
Was actually asking just out of curiosity. Water cooled 911 are coming down in price...
911 w/ 3.2
Old 06-26-2018, 02:20 PM
Puny Bird
Mark Henry's Avatar
Yes and no, maybe in SoCal but prices are pretty steady ROW.
Also depends on the model and condition, for example the C4S is still fairly sought after.
Old 06-26-2018, 02:30 PM
Early ones are still falling here.
https://losangeles.craigslist.org/sfv/cto/d/1999-porsche-911-carrera/6627115448.html
911 w/ 3.2
Old 06-26-2018, 04:49 PM
Gotcha
Old 06-26-2018, 05:17 PM
Puny Bird
Mark Henry's Avatar
Originally Posted by tdskip View Post
I would strongly recommend a PPI with a borescope, manometer, code check, cam deviation, oil filter inspection, crank thrust check, etc., and the regular stuff.
The borescope insist on pictures of each cylinder, some shops have been known to cheat on this inspection.
It will cost $4-600 but well worth it, way cheaper than a new engine.
The dual row IMS bearing is less problematic, but I would factor the price for it when you need to replace the flywheel/clutch.
Parts prices are about 4 time the cost of 914 parts prices. 996's also go through tires a lot faster, of course how fast depends on how you drive it.
You don't want this:
Old 06-26-2018, 05:43 PM
Thanks Mark
911 w/ 3.2
Old 06-26-2018, 05:44 PM
