Necessary to remove both wrist pin circlips for piston removal?
Hi everyone,
I've been mostly posting in Technical Forum, but may switch to this one. Not sure of protocol. Assume mostly same people? Car is 1989 911 Carrera 3.2 with 200+K miles. Tearing down for a rebuild. Sending cylinders out for bore out to 3.4 and coating, and buying new pistons.
I have engine disassembled down to point of piston removal. Question is, do I need to remove BOTH circlips to get wrist pin to point of piston removal, or just 1? Everywhere I read in formal texts (Wayne's book and Bentley), it says remove circlips in plural. If it's not necessary, why take the chance of damaging a piston during prying/pulling of circlip out?
Does it matter which circlip I remove and which way I press the wrist pin? One side is deeper to circlip than the other. Planning to start with piston 1 per Bentley, and press toward flywheel end. If authorized, I'd only remove the clip on flywheel side.
Also, per forums, planning on just using screwdriver handle as a drift. OK?
Thanks!
Mark
2009 Audi A4 2.0TQA
2017 BMW X3
2007 BMW 328xi
1971 BMW R60/5
Old 07-07-2018, 06:27 AM
175K911's Avatar
You only need to remove one circlip. Then tap the pin out that side.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 07-07-2018, 07:10 AM
Excellent. Thank You!
Old 07-07-2018, 08:02 AM
Heat the piston slightly with a heat gun or propane torch, the pins will slide right out.
-Andy
Old 07-07-2018, 10:44 AM
Thanks Eagledriver. Too late, already tapped them out with the screwdriver handle. Didn't really require much. I do have to admit that I was mildly concerned with the load on the rod bearings in an axis that they were never intended to see. If I had to do more than a tap tap, I'd have tried to figure out a way to hold the rod.
Next step, splitting the case. All uncharted territory for me...
Thanks again,
Mark
2009 Audi A4 2.0TQA
2017 BMW X3
2007 BMW 328xi
1971 BMW R60/5
Last edited by Dauner; 07-08-2018 at 09:54 AM.. Reason: Incorrectly said "main" instead of "Rod" bearings...
Old 07-07-2018, 05:10 PM
Jeff Alton's Avatar
The 3.2 pins always slip out easy, while some 3.0 pins can be stubborn and require a touch of heat...
www.turn3autosport.com
Old 07-08-2018, 05:52 PM
Thanks again,
Mark
Don't forget the "hidden bolts" in the chain through-way and the 3 behind the flywheel which needs to come off.
Old 07-09-2018, 03:40 AM
Buy Wayne's book: How to Rebuild and Modify Porsche 911 Engines.
Best $30 you'll spend on your rebuild. Especially if it's your first....
There's a complete section on dis-assembly
Old 07-09-2018, 07:24 PM
Jeff Alton's Avatar
Great book. Good resource.
But, research some of the assembly techniques (sealing things up) before assembling your engine.
Cheers
Old 07-09-2018, 07:30 PM
