Necessary to remove both wrist pin circlips for piston removal?
Hi everyone,
I've been mostly posting in Technical Forum, but may switch to this one. Not sure of protocol. Assume mostly same people? Car is 1989 911 Carrera 3.2 with 200+K miles. Tearing down for a rebuild. Sending cylinders out for bore out to 3.4 and coating, and buying new pistons. I have engine disassembled down to point of piston removal. Question is, do I need to remove BOTH circlips to get wrist pin to point of piston removal, or just 1? Everywhere I read in formal texts (Wayne's book and Bentley), it says remove circlips in plural. If it's not necessary, why take the chance of damaging a piston during prying/pulling of circlip out? Does it matter which circlip I remove and which way I press the wrist pin? One side is deeper to circlip than the other. Planning to start with piston 1 per Bentley, and press toward flywheel end. If authorized, I'd only remove the clip on flywheel side. Also, per forums, planning on just using screwdriver handle as a drift. OK? Thanks! Mark
1989 911 Carrera 3.2 2009 Audi A4 2.0TQA 2017 BMW X3 2007 BMW 328xi 1971 BMW R60/5 |
You only need to remove one circlip. Then tap the pin out that side.
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
Excellent. Thank You!
Heat the piston slightly with a heat gun or propane torch, the pins will slide right out.
-Andy
72 Carrera RS replica, Spec 911 racer |
Thanks Eagledriver. Too late, already tapped them out with the screwdriver handle. Didn't really require much. I do have to admit that I was mildly concerned with the load on the rod bearings in an axis that they were never intended to see. If I had to do more than a tap tap, I'd have tried to figure out a way to hold the rod.
Next step, splitting the case. All uncharted territory for me... Thanks again, Mark
1989 911 Carrera 3.2 2009 Audi A4 2.0TQA 2017 BMW X3 2007 BMW 328xi 1971 BMW R60/5 Last edited by Dauner; 07-08-2018 at 09:54 AM.. Reason: Incorrectly said "main" instead of "Rod" bearings... |
The 3.2 pins always slip out easy, while some 3.0 pins can be stubborn and require a touch of heat...
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Don't forget the "hidden bolts" in the chain through-way and the 3 behind the flywheel which needs to come off.
1979 930 |
Buy Wayne's book: How to Rebuild and Modify Porsche 911 Engines.
Best $30 you'll spend on your rebuild. Especially if it's your first.... There's a complete section on dis-assembly |
Great book. Good resource.
But, research some of the assembly techniques (sealing things up) before assembling your engine. Cheers
