Chain fence eating turbo
Wrightwood Racing oil pump square ‘O’ rings
Are they all the same? Wayne’s book shows green ones and orange ones and Bentley states there are 2 sizes.
Aren’t the Wrightwood Racing ones all the same size?
Old 07-14-2018, 12:11 PM
BURN-BROS's Avatar
There are 2 sizes Wrightwood supplies . scavenge and the top two on the cooler is smaller. supply side of pump and cooler is larger diameter
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 07-14-2018, 02:24 PM
proporsche's Avatar
jut a pick for the size..as Aaron said..
1985 911 with original 502 191 miles...808 198 km
Old 07-14-2018, 02:44 PM
Thanks guys
Old 07-14-2018, 05:18 PM
I assume the ones in the low end kit are 1 for case to case and the other 4 for the pump???
Old 07-14-2018, 05:19 PM
I have my cases together, and both the Bentley and Wayne’s book mentions 2 sizes.
Doubting myself right now
Old 07-14-2018, 05:20 PM
Inside the case is a large one behind the pump, two small on the pump and one between the cases.
Having had them displaced while mating the case halves I use aviation permatex to hold them in place.
Bruce
Old 07-15-2018, 04:14 AM
I've used a little wheel bearing grease on them to help stick them in place while putting the case halves together or installing the oil cooler.
Old 07-15-2018, 05:50 AM
