Valve Spring Compressor for 964
I’m onto my second rebuild and this time I will do the heads (last time was essentially a reseal as the top end had already been done).
What size valve spring compressor tool should I order? Are there any size constraints, features etc required or will a generic size fit?
This won’t be used often as I expect two rebuilds will be my limit so I don’t want to go crazy prices if I can avoid it.
TIA
Old 08-04-2018, 03:00 PM
abit off center
cgarr's Avatar
I use my same one for the 911 heads
______________________
Craig
G2Performance
Old 08-06-2018, 11:26 AM
